Show that the T is a linear transformation
10 replies · 2K views · last reply
Dank2
T:R2[x] --> R4[x]
T(f(x)) = (x^3-x)f(x^2)
Let f(x) and g(x) be two functions in R2[x].
T(f(x) + g(x)) = T(f+g(x)) = (x^3-x)(f+g)(x^2) = (x^3-x)f(x^2) + (x^3-x)g(x^2) = T(f(x)) + T(g(x)).
let a be scalar in R:
aT(f(x)) = a(x^3-x)f(x^2) = (x^3-x)af(x^2) = T(af(x)).
Dank2 said:
T:R2[x] --> R4[x]
So, what is your question for us?
Title, to show that T is linear transformation, what i did is enough?
I suggest you try to answer that for yourself. Ask yourself: have you verified all the required properties that a linear transformation would have? If you are unsure, then ask yourself which properties you think you have missed.
These are the two properties that is required, but the way that it's shown, since it's with a function, is correct?
Dank2 said:
T:R2[x] --> R4[x]
What are R2[x] and R4[x]?
Are these polynomials with real coefficients of degree less than 2 and 4, respectively?
that's correct.
I have been told now it should be R6[x].
How can i see that it's right?, that's it R6[x] and not R4[x] or i can't see it and it depends on f(x) and it's pre-defined?
Who told you that?
Since ##f \in R_2[x]##, then f(x) = ax +b, right? According to the formula you posted, what is T[f(x)]?
Mark44 said:
f∈R2[x]
Forgot about that simple fact.
T(f(x)) = T(ax+b)= (x3-x)*(ax2+b) , which is really a polynomial of degree 5 , so the image of transformation is indeed at R6[x] - All the polynomial of degree 5 or less.3
Mark44 said:
Who told you that?
class teacher.
I got confused since different textbooks describe spaces like R6[x] as "polynomials of degree less than 6" and others describe the as "polynomials of degree less than or equal to 6." Also, the notation I've seen many times is p2[x] to mean the same as your R2[x].
The work you did in the first post seems OK to me, but I think the intent of the problem is that you should show how things work with the specific spaces that are given. It should be easy to show that T[f + g] = T[f] + T[g] and that T[af] = aT[f], but I believe they want you to use generic functions in R2[x].
