Showing a double integral lies between two bounds
  • Thread starter Thread starter Kuma
    Proof
10 replies · 2K views
Kuma
Hi. I have been given the following question.
Show that this is true:
Well I drew out the region and the bounds. I'm pretty sure that it isn't possible to integrate this because no matter the order, I need either an x or a y in there to do a substitution. So I'm guessing that I just have to show in some way that the final integral solution will lie between those two numbers, but I don't know how to approach this.
Think about how large and how small the integrand can be on that domain.
Try your luck with a polar transformation if you want to save time on the integral.
I didn't do polar transformations yet.
That domain is a square, but how can i find how large it can be without knowing the integral?
ex2 + y2 will have its largest value at one of the corner points of the region. Similarly, this function will have its smallest value at another of the corner points.
Makes sense, but I'm not sure how i can show that without doing the integral itself.
You DON'T need to calculate the integral. This problem is basically an extension of the ideas behind approximating an integral using a Riemann sum. Instead of using rectangles to get an upper and lower estimate for the area beneath a curve, here you're using boxes to get upper and lower estimates for the volume beneath a surface.
dextercioby said:
You can't use a polar transformation, because the domain is a finite rectangle.
Actually, to be pedantic, he could use a polar transformation if he had studied that, but it would be pointless and wouldn't help.
@Kuma: Use the theorem if m ≤ f(x,y) ≤ M on a region R then
[tex]m\cdot Area(R) \le \iint_R f(x,y)\, dydx\le M\cdot Area(R)[/tex]
The polar transformation is applicable to subsets of disks, not to rectangles. For rectangles, cartesian coordinates are valid.
dexter, you can use polar coordinates over whatever domain you choose, it's just going to be hard to write down the limits of the inside integral
