Simple trig identification equation question which i can not answer
  • Thread starter Thread starter i-love-physics
    Identification Trig
5 replies · 4K views · last reply
i-love-physics
Solve for X
2sin^2x - cosX - 1 = 0
I have gone in this order
I turned 2sin^2x into 1 - cos2x
so
1 - cos2x - cosx -1 = 0
This turns into
Cos2x + cosx = 0
I don't know what to do next...
could someone please help :(, much appreciated
I'm not sure if you mean 2 times sin x squared or 2 times sin 2x?
But it if is former, then...
2(sin x)^2 - cos x - 1 = 0
2(1 - [cos x]^2) - cos x - 1 = 0
2 - 2[cos x]^2 - cos x - 1 = 0
-2[cos x]^2 - cos x + 1 = 0
from here you just treat it as you would a quadratic equation.
Follow up...
Following on Kuno's advice, you have:
-2 cos^2 x - cos x + 1 = 0
Which is really like asking:
-2x^2 - x + 1 = 0
In other words: (-2x + 1)(x+1) = 0
x = -1, x=1/2
Thus you are really asking, when does :
cos x = -1 ?
and when does
cos x = 1/2 ?
Which happens when
x = pi, x = pi/3 or if you prefer degrees: x = 180, 60
Which is the answer to your problem. (Assuming of course that you wanted to write 2 * sin^2 x and not 2*sin 2x)
thank you, thank you, thank you, thank you, thank you SO MUCH!.
I realize what i did wrong, i was using the wrong identity, you know how
cos2a = 2sinx^2 -1
I was using that identity instead of the sin^2x + cos^2x = 1 identity.
Just out of curiousity, say i used that first identity and got the answer
cos2x +cosx = 0
Is it possible to solve a equation like that or not ?
cos2a = 2sinx^2 -1
Actually that should read:
cos 2x = 1 - 2 sin^2 x
This second identity allows you to say also:
1 - 2*sin^2 x = 1 - 2*(1 - cos^2x) and thus:
cos 2x = 2*cos^2 x - 1
cos2x +cosx = 0
I guess you really mean to ask: Does the equation :
cos 2x + cos x = 0
Have any solutions? (assuming for 0..x..2pi)
Well, we can start with this identity (the double angle formula):
We have the following:
2*cos^2 x + cos x - 1 = 0
Which is like the following:
2u^2 + u - 1 = 0
or (u+1)(2u-1)=0 that is, u = -1, u=1/2
Thus our question really means :
When does u (that is cos x) = -1,1/2 or:
when does cos x = -1, cos x = 1/2 ?
Thus x = pi, pi/3
You will find that many many equations of this sort are solved in this manner - you are essentially doing what we call "substitution" of a function, something very common in calculus - reducing a problem to a format which has a known solution. In this case you are reducing trigonometric functions to a polynomial, solving the polynomial and then finding when the trigonometric function has those values.
Here is also a good page for Trigonometric identities:
http://www.sosmath.com/trig/Trig5/trig5/trig5.html
JJ +
[tex]\cos^2{x} + \cos{x} = 0[/tex]
substitute with x:
[tex]x^2 + x = 0[/tex]
[tex]\frac{-1 \pm 1}{2}[/tex]
[tex]x_1 = -1[/tex]
[tex]x_2 = 0[/tex]
[tex]\cos{x} = -1[/tex]
[tex]\arccos{-1} = \pi[/tex]
[tex]\cos{x} = 0[/tex]
[tex]\arccos{0} = \frac{\pi}{2}[/tex] and [tex]\frac{\pi}{2} + \pi = \frac{3\pi}{2}[/tex]
[tex]x = \frac{\pi}{2} , \pi , \frac{3\pi}{2}[/tex]
