Simplifying 2a/(a²-4) - 1/(a-2)
  • Topic:
  • Thread starter Thread starter mathlearn
    Fraction
7 replies · 2K views · last reply
mathlearn
$\frac{2a}{a^2-4} - \frac{1}{a-2}$
Now using difference of squares in $a^2-4$ = $\left(a+2\right) \left(a-2\right)$
Then the fraction would be $\frac{2a}{\left(a+2\right) \left(a-2\right)} - \frac{1}{a-2}$
Can this fraction be simplified further?
Many Thanks :)
Mathematics news on Phys.org
What is your LCD if you are going to combine the two fractions as indicated by subtraction?
That would be to make denominators equal
Then the fraction would be $\frac{2a}{\left(a+2\right) \left(a-2\right)} - \frac{1*\left(a+2\right)}{a-2*\left(a+2\right)}$
Which now equals in $\frac{2a}{\left(a+2\right) \left(a-2\right)} - \frac{\left(a+2\right)}{(a-2)\left(a+2\right)}$
Which I guess would result in $\frac{2a}{\left(a+2\right) \left(a-2\right)} - \frac{\left(a+2\right)}{(a-2)\left(a+2\right)}$
$ \frac{a+2}{(a-2)\left(a+2\right)}$
Correct ? :)
Correct ? :)
Yes, you have the correct LCD:
$$\frac{2a}{(a+2)(a-2)} - \frac{1}{a-2}\cdot\frac{a+2}{a+2}=\frac{2a}{(a+2)(a-2)} - \frac{a+2}{(a+2)(a-2)}$$
But, you made an error in your subtraction:
$$\frac{2a}{(a+2)(a-2)} - \frac{a+2}{(a+2)(a-2)}=\frac{2a-(a+2)}{(a+2)(a-2)}=\frac{2a-a-2}{(a+2)(a-2)}=\frac{a-2}{(a+2)(a-2)}$$
Now, all that's left is to divide out any factors common to the numerator and denominator. :D
$\frac{\cancel{a-2} }{(a+2) \cancel {(a-2)} } = (a+2)$
Correct ? :)
Correct ? :)
How did $a+2$ move from the denominator to the numerator?
Oh! That's a mistake :D
$\displaystyle \frac{2a}{(a+2)(a-2)} - \frac{a+2}{(a+2)(a-2)}=\frac{2a-(a+2)}{(a+2)(a-2)}=\frac{2a-a-2}{(a+2)(a-2)}=\frac{a-2}{(a+2)(a-2)}$
$\frac{\cancel{a-2} }{(a+2) \cancel {(a-2)} } =\frac{1}{(a+2)} $
Many Thanks MarkFL (Smile) (Party)
You almost have it...We have a slight problem. The expression 1/(a + 2) comes out all right, but the original expression says that a can't be either -2 or 2. We have to list that in the final answer as well. So your solution is 1/(a + 2), a not equal to -2, 2.
(Technically 1/(a + 2) means we can't have a = -2 anyway, so all we really need is a not equal to 2.)
-Dan
