Simplifying a math equation
  • Level: High School
  • Thread starter Krasz
    Math equation
11 replies · 3K views · last reply
Krasz
Hey guys i have been attempting this problem for days. If you can help me with it and explain how to solve it, I would be extremely grateful. I wrote my answer on the right. Thanks!
  • Handwritten nested fraction: 1 + 1 over x + 1, over x + 1, over x + 1, over x + 1, with the expression written as a continued fraction. Beside it is the handwritten result x^6 + x^5 + x^4 + x^3 + x^2 + x + 2.
The image isn't loading for me - could you possibly just type the equation in or is it too complex?
Oscar
Ill give it a whirl.
1+1/x+1/x+1/x+1/x+1
Now, the second number in the equations is always the one being divided by x + 1.
It is not both numbers that are divided, just the second. This series goes all the way down.
So is it like this?
[tex] 1+\cfrac{1}{x+\cfrac{1}{x+\cfrac{1}{x+\cfrac{1}{x+1}}}}[/tex]
Start with the bottom:
[tex]x+\frac{1}{x+1}=\frac{x^{2}+x+1}{x+1}[/tex]
Now, the next calculation will be:
[tex]x+\frac{x+1}{x^{2}+x+1}=\frac{x^{3}+x^{2}+2x+1}{x^{2}+x+1}[/tex]
You then have:
[tex]x+\frac{x^{2}+x+1}{x^{3}+x^{2}+2x+1}=\frac{x^{4}+x^{3}+3x^{2}+2x+1}{x^{3}+x^{2}+2x+1}[/tex]
Thus, we finally get:
[tex]1+\frac{x^{3}+x^{2}+2x+1}{x^{4}+x^{3}+3x^{2}+2x+1}=\frac{x^{4}+2x^{3}+4x^{2}+4x+2}{x^{4}+x^{3}+3x^{2}+2x+1}[/tex]
Thanks, but could you explain your reasoning for doing each step?
Not unless you point specifically at what you didn't understand.
How did you get from step 2 to step 3? Such as how did 2x come into play?
After step 1, we have the following "bottom part":
[tex]x+\frac{1}{\frac{x^{2}+x+1}{x+1}}=x+\frac{x+1}{x^{2}+x+1}[/tex]
Agreed thus far?
Now, we find a common denominator to the above sum:
[tex]x+\frac{x+1}{x^{2}+x+1}=\frac{x*(x^{2}+x+1)+x+1}{x^{2}+x+1}[/tex]
Calculate the numerator of this expression!
Agreed thus far?
Thank you so much I see it now! You were a great help!
Even though they have not been assigned as exercises, I am sure your textbook contains a few more problems of the same type.
Do some of them to make sure you master the technique on your own!
Good luck! :smile:
