Simplifying a product rule derivative expression
  • Thread starter Thread starter mimi.janson
16 replies · 4K views · last reply
mimi.janson
reduce this one
f´(x)=(12x^3+12x)*(1/2 x^2+3)+(3x^4+6x^2+1)*(x)
i have to make all the () disappear and make it shorter
the thing i have to use are the normal rules about ^n
ive tried to reduce it this way but i don't know why i just feel its wrong so if someone could show me how to do step by step
f´(x)=6x^5+36x^3+6x^2+36+4x^4+7x^2+x
Your answer is not correct. It'll be easier to help you if you show us exactly what you've tried. It's a straightforward problem, just expand the brackets with FOIL and combine like terms.
[tex] a*(b+c+d)+b*(a+g+h) = ab+ac+ad+ab+ag+ah = 2ab + ac + ad + ag + ah[/tex]
That's almost all you have to do.
yes i know the rules you have posted but my problem is that i can't only say a*(b+c) since i have a*(b^n + c^n)
I can't really post a solution, it's against forum rules. Show us what you've done, and we can see where you went wrong. Here's a better example:
[tex] x^{2}(3x^{4}+6x^{3}-\frac{1}{2}x^{2}) = 3x^{6}+6x^{5}-\frac{1}{2}x^{4}<br /> [/tex]
Of course you can: just set B = b^n and C = c^n; now you have a*(B+C). You need to realize that in rules such as a*(b+c) = a*b + a*c, the a, b and c can be ANY algebraic or numerical quantities.
RGV
RGV
so if we just use numbers as an example and let's say
a*(b^n + c^n)
2*(3^4+5^6) then that mean you are telling me that usally you have to solve the ^ first so it ends up being 2*(81+15625) ? and then 162+31250 ? but it seems so strange how i can use it since i have like x^n ? i don't really know what x is anyway
when i look at the (3x^4+6x^2+1)*(x)
i don't know what (3x^4)*x is should i say 4x^4 or 3x^5 ? i don't know if my x goes to the 3x or to the ^4
The rule is:
[tex] ax^{n}\cdot x^{m} = ax^{n+m}[/tex]
Now you can use this to expand your brackets, making sure to preserve the order of operations (Sometimes remembered using BEDMAS : brackets, exponents, division/multiplication, addition/subtraction).
DivisionByZro said:
The rule is:
then it means my (3x^4+6x^2+1)*(x)
becomes (3x^4+6x^2+1) since there isn't any x^n but only x on the right side
a*(b^n + c^n)
No, I never said what you claim I am saying. I say that 2*(3^4+5^6) equals 2*(3^4) + 2*(5^6). Whether or not you choose to put 3^4 = 81 and/or 5^6 = 15625 before, or after the expansion, or not at all, is purely a matter of personal choice.
I don't see you problem with having x^n; x^n is just another algebraic quantity, no better or worse than plain x itself. In your example y = x*(3x^4 + 6x^2 + 2), you just expand each term separately, so y = x*(3x^4) + x*(6x^2) + x*(2) = 3x^5 + 6x^3 + 2x. That's all there is to it.
Finally, your question "i don't know what (3x^4)*x is" puzzles me. You just keep all the x's together and all the numbers separate, so x*(3x^4) = 3 x x^4 = 3x^5. You most certainly cannot get (3x^4)*x = 4x^4 as you suggest; just plug in a value such as x = 1 or x = 2 and see if it works (t doesn't).
RGV
a*(b^n + c^n)
Finally, your question "i don't know what (3x^4)*x is" puzzles me. You just keep all the x's together and all the numbers separate, so x*(3x^4) = 3 x x^4 = 3x^5. You most certainly cannot get (3x^4)*x = 4x^4 as you suggest; just plug in a value such as x = 1 or x = 2 and see if it works (it doesn't).
RGV
RGV
ok sorry i misunderstood it
if i have x*2x^6 = 2x^7 which means i just add it to the 6 right and if i have 5x^3*4x^2 itl make 20x^6 ? i really liked your last explanation thank you a lot
Almost there.
[tex] 5x^{3}\cdot4x^{2} = (4\cdot5)x^{3+2} = 20x^{5}[/tex]
Here's the difference between adding polynomials and multiplying them:
Adding:
[tex] <br /> 3x + 2x + 2x^{2} - x^{2} = (3x+2x)+(2x^{2} - x^{2}) = 5x + x^{2}<br /> [/tex]
All the ones with equal powers (Ex: 2x and 3x have equal powers, 1 and 1: 2x=2x^1) are grouped together.
You can add and subtract monomials/polynomials with the same base (i.e. x^{2} and 2x have the same base, x) AND the same powers. So:
You can't add/subtract these two any more than this:
[tex]2x - 3x^{2}[/tex]
But you can add/subtract these:
[tex]3x+4x[/tex]
Because they have the same base and the same power.
Now for multiplying:
[tex]3x^{2} \cdot 3x = (3)\cdot x^{2+1} = 3x^{3}[/tex]
You can multiply two monomials as long as they have the same base ("x" in this example). You cannot further simplify/multiply these two:
[tex]a^{2} and x^{3}[/tex] because they aren't the same monomials.
Here's a final example to summarize all of this:
[tex]\begin{align*} <br /> & x(1+3x+2x^{2}-3x^{4}) + 2x^{2}(1-\frac{1}{2}x^{2}) \\<br /> & = (x\cdot1)+(x\cdot3x)+(x\cdot2x^{2})+(x\cdot -3x^{4})+(2x^{2}\cdot1)+ (2x^{2}\cdot \frac{-1}{2}x^{2}) \\<br /> & = x+3x^{1+1}+2x^{2+1}-3x^{1+4} + 2x^{2} - (2\cdot \frac{1}{2})(x^{2+2}) \\<br /> & = x+ 3x^{2} + 2x^{3} - 3x^{5} + 2x^{2} - x^{4} \\ <br /> & = x + 5x^{2} + 2x^{3} -x^{4} -3x^{5} \\ <br /> \end{align*}[/tex]
Does this help?
DivisionByZro said:
Almost there.
Adding:
[tex]3x+4x[/tex]
[tex] <br /> <br /> \begin{align*} <br /> & x(1+3x+2x^{2}-3x^{4}) + 2x^{2}(1-\frac{1}{2}x^{2}) \\<br /> & = (x\cdot1)+(x\cdot3x)+(x\cdot2x^{2})+(x\cdot -3x^{4})+(2x^{2}\cdot1)+ (2x^{2}\cdot \frac{-1}{2}x^{2}) \\<br /> & = x+3x^{1+1}+2x^{2+1}-3x^{1+4} + 2x^{2} - (2\cdot \frac{1}{2})(x^{2+2}) \\<br /> & = x+ 3x^{2} + 2x^{3} - 3x^{5} + 2x^{2} - x^{4} \\ <br /> & = x + 5x^{2} + 2x^{3} -x^{4} -3x^{5} \\ <br /> \end{align*}<br /> <br /> [/tex]
Does this help?
Does it help ? No it doesn't help
it does help me in the most perfect way ever !...i am so much sure that your explanation is even better than my book ! i really like the exampels you gave couse you can relate more instead uf just heavy rules ...its easier to understand and remember this way so i thank you very much for your help and assure you that I am going to use your explanation as my personal notes to remember and train them so i can learn it all :=) thank you a thousand times again
You're quite welcome! :smile:
People here are always happy to help you as long as you've shown some effort. Good luck!
thank you a lot :=)
[/color]
I make this 9x3
NascentOxygen said:
[/color]
I make this 9x3
Oops typo. Thanks for spotting it! However, for some reason I can't go back and edit it.
