Sojourn time in subset of states for Markov process?
This discussion focuses on estimating the sojourn time within a subset of states in a Markov process. The participants suggest using an absorbing state to simplify the exit time calculations, leading to a matrix formula based on state transition probabilities. They explore the possibility of defining distance measures for nodes to facilitate hitting time calculations and consider diffusion models as potential solutions. The conversation emphasizes the need for parameters that characterize the network structure to avoid complex matrix computations.
  • Understanding of Markov processes and state transition probabilities
  • Familiarity with absorbing states and their role in exit time calculations
  • Knowledge of diffusion models and their application in probabilistic systems
  • Basic concepts of graph theory and network topology
  • Research "Markov process exit time calculations" for detailed methodologies
  • Explore "diffusion models in probabilistic systems" to understand their applications
  • Learn about "absorbing Markov chains" and their implications in state transitions
  • Investigate "graph theory metrics" to define distance measures in networks
Researchers and practitioners in applied mathematics, data scientists working with probabilistic models, and anyone involved in analyzing Markov processes and network dynamics.
Gerenuk
I have a graph where from each node the state can change randomly from one node to some of the other nodes. My task is to estimate how long the state will stay within a subset of all these nodes.
Is there a way to characterize the network with some parameters to find the answer (maybe for a specific subset)?
Maybe averaging over node going out of this set or determining some fractal stuff or so?
To work out the "exit time" (or equivalently "hitting time") distribution for a fixed finite subset is no problem. One strategy is to merge all the outside states into a single absorbing state z so that P(T<=t) = P(X(t)=z) holds. This reduces to a neat matrix formula in terms of the state transition probabilities and starting state probabilities.
Not sure how to parameterize as a function of subsets though. Hope this helps!
Oh true.
I haven't dealt with this mathematically, but I vaguely know the concepts.
Is it possible to define some sort of distance for all of the subset nodes so that I can find the hitting time easier?
Basically I'm looking for techniques to define in advance parameters for each node, so that later I could calculate these exit probabilities easy (maybe a summation or so).
The question is: Is there a way to avoid the full matrix calculation?
Maybe to get at least approximate results.
Depends - what else is known about the network structure?
It's not a specific problem. I'm rather trying to think about theory of physical processes. So I could know whatever you wish :smile:. Once I have these reduced parameters for the network (maybe one for each node) I'd like to find exit times for arbitrary regions. Or maybe for a fixed region but arbitrary starting point at least.
Or at least get to the solution of that problem as close as possible. I think I'd like to do local calculations only if that is possible.
Ok if it's a physical system with a large number of locally connected states then perhaps a diffusion model could be used? There are some results relating exit times with PDEs though I'm not familiar with the details.
A solution similar to a diffusion model would be good.
I just suspect that the topology in graphs isn't comparable to normal space. So it would be nice to know how to derive some distance measure or a parameter that tells if distances are appropriate at all. Maybe also some fractal stuff?
Maybe jump-diffusion then?
You might well find that the original matrix solution is the simplest, if the transition probs can take on arbitrary values. The matrix solution effectively gives the exit probabilities as a function of the starting state.
I think it's a good assumption to say that the processes are in a continuous space and some sort of diffusion can be applied. Now the questions are
How do I calculate the exit time given a starting point and the "shape" of the region.
What sort of topology describes the state space? With all sorts of connections I could imagine that there are weird metrics? Or how else can one characterise a graph network?
  • · Replies 93 ·
