Solving Solubility Problem: I_2\text{(s)} in KI(aq)
  • Thread starter Thread starter broegger
    Solubility
The solubility of iodine (I2(s)) in a 0.1 M potassium iodide (KI) solution is calculated to be 0.0489 M, significantly higher than its solubility in pure water, which is 0.0013 M at 25ºC. This increase is due to the equilibrium reaction I2(aq) + I-(aq) <=> I3-(aq) with a constant K of 700 M-1. The addition of I- ions from KI shifts the equilibrium to the right, enhancing the solubility of I2(s) in the solution.
  • Understanding of solubility equilibria
  • Familiarity with Le Châtelier's Principle
  • Knowledge of equilibrium constants (K)
  • Basic chemistry concepts related to ionic compounds
  • Study the application of Le Châtelier's Principle in various chemical equilibria
  • Learn about calculating solubility products (Ksp) for different compounds
  • Explore the concept of complex ion formation in solution
  • Investigate the effects of ionic strength on solubility
Chemistry students, educators, and professionals preparing for exams or working on solubility and equilibrium problems in aqueous solutions.
broegger
Hi. I'm preparing for a chemistry exam and I have trouble with this former exam problem:
The solubility of I_2\text{(s)} in water at 25ºC is 0.0013 M.
Calculate the solubility of I_2\text{(s)} in a 0.1 M solution of KI(aq) by considering this equilibrium:
I_2\text{(aq)}+I^-\text{(aq)} \leftrightharpoons I_3^-\text{(aq)}, \quad K = 700 M^{-1}​
I assume that I2(s) just dissolves like I2(s) <-> I2(aq). I have found the solubility to be 0.0489 M, but I lack a systematic way of solving this. Any hints?
I_2 (s) \leftrightharpoons I_2 (aq)
That's the solubility reaction of I_2.
Now, consider that you add a a 0.1 M solution of KI. One of the ions of this salt, I^-, reacts with I_2 (aq). Acoording to Le Châtelier's Principle what will happen to the equilibrium above since the concentration of I_2 (aq) got lower.
It will shift to the right, so the solubility will go up (consistent with my result.) I should compute the I3- concentration and add it to the I2(aq) concentration to find the new solubility, right?
How did you found that solubility?
Hmm, not sure. But I think I know how to do it now. Thanks.
10K
11K
11K
