Solve Modular Equation for Integer y: 35y = 42 (mod 144)
  • Thread starter Thread starter duki
7 replies · 2K views
duki
Find the integer y with both 0 < y < 144 and 35y = 42(mod 144)
Can someone help me get started on this one? I understand that I can reduce it to 5y = 6(mod 144), and then to 5y = 6 + 144... but I'm not sure what to do with that. I mean, can I just do 5y = 150 and then y = 30?
If you plug [tex]y = 30[/tex] into the original equation, is it true? If so, then you're done.
An interesting question to consider: if instead of 35, the original equation had 36, then your method would fail. Why? Does the equation have a solution in that case?
A more ambitious question: what is a necessary and condition upon k in order for
ky = 42 (mod 144)
to have a solution? Does the answer change if instead of 42 you use some other number between 0 and 143?
I'm a little confused here. So if I plug my answer into the equation and it doesn't work, it means there are no solutions? And I don't know the answer to the second question
I have another one here:
0 < x < 41
19x = 22(mod 41)
You're right, my previous method didn't work. What can I do?
0 < x < 41
19x = 22(mod 41)
Do you know this theorem:
ax = b (mod n)
has a solution if and only if gcd(a,n) divides b.
In this case, gcd(a,n) = 1 since 19 and 41 are relatively prime. So a solution does exist.
Any solution to this equation:
ax + kn = b, where k is any integer
is also a solution to
ax = b (mod n)
There is a well-known algorithm for finding integers x and k that satisfy
ax + kn = b
provided that a solution exists. Are you familiar with it?
No. :(
I'm still stuck on this... can anyone give me a hand?
0 < x < 41
19x = 22(mod 41)
Saying 19x= 22 (mod 41) means that 19x= 22+ 41k for some integer k. That is the same as 19x- 41k= 22. 19 divides into 41 2 times with remainder 3 so 41= 2(19)+ 3 or 41- 2(19)= 3. 3 divides into 19 6 times with remainder 1: 19- 6(3)= 1 and then 19- 6(41- 2(19))= 3(19)- 6(41)= 1. Multiplying by 22, 66(19)- 132(41)= 22. Thus one answer is x= 66. That's not the answer you want because it is too big but you should be able find the correct answer.
