Solve Radical Equation: (2 root 3 + 3 root 4)/-5
  • Thread starter Thread starter wScott
    Radical
6 replies · 4K views
wScott
This isn't exactly homework, it was a question we had on a test and I had no idea at all of how to do it, although I think I did good on the other questions.
The result that it came to, I can't remember exactly what it was, looked kind of like this:
(2 root 3 + 3 root 4) over (-5)
My teacher won't let us have any question with a negative denominator. My question is how do you remove the negative from the bottom.
EDIT: Sorry I couldn't figure out how to LaTeX this problem.
Your LaTeX cannot be seen. Could you write the fraction normally?
Sorry about that, it's fixed.
You can take it outside the fraction or put it to the top. The fraction still has the same value;
[tex]\frac{a}{-b} \equiv \frac{-a}{b} \equiv - \frac{a}{b}[/tex]
They are all identical, but it is usually more acceptable to have the negative 'outside' the fraction as in the third example. :smile:
Ahh makes sense to me, thanks for the help. I definitely screwed that up. For my answetr I came out with fractional radicals under 1 :p
Hootenanny explained it very well. But I could add a tip.
Your fraction is:
If you divide all the terms of the fraction by the same number you mantain it equal to the initial fraction.
In this case you could divide by -1. So, we would have:
(-2 root 3 - 3 root 4) over (5)
