Solving |2x - 1| = x^2
2 replies · 2K views
majormuss
how do I solve this? I am confused...
|2x - 1| = x^2
when i tried it I ended up with a solution set of (1,-1). But the official answer is quite different so I am confused!
The absolute value function is defined as follows:
[tex]|x| = x, x\geq 0[/tex]
[tex]|x|= -x, x< 0[/tex]
But you have 2x-1 so replace the x in the absolute value for 2x-1. Try this and then solve both equations [itex]2x-1=x^2[/itex] and [itex]-(2x-1)=x^2[/itex]. Once you find your solutions, remember to be sure to scrap the solutions that aren't valid. That is, if you get an answer of -10 for [itex]2x-1=x^2[/itex] then you know it's not valid because we are assuming 2x-1>0, or, x>1/2.
You could also approach this graphically.
Imagine the line y=2x-1, that's a line with a positive slope and intercepts the y-axis at (0,-1). Now, |2x-1| refers to the absolute values of y (i.e. |y|) so you have to reflect what is below the x-axis in the x-axis itself to get your |y|=|2x-1| which looks like a 'V' shaped graph. The function of the graph that you obtain can be defined as follows:
[tex]y = 2x-1 for x >= \frac{1}{2}[/tex]
and
[tex]y = 1 - 2x for x <= \frac{1}{2}[/tex]
Now all you have to do is sketch the graph of [tex]x^2[/tex] on top of that and simply determine where your V-shaped graph (y=|2x-1|) is equal to the graph of y=x^2 by finding the points of intersection.
