Solving a V-vs-s Problem: John's Quandry
  • Thread starter Thread starter John Mohr
11 replies · 2K views · last reply
John Mohr
A 2500 kg car changes from a velocity of 15 m/s to 25 m/s over a distance of 450 m. What is the work done on the car by the engine?
W = Fd, Delta E = 1/2mdeltav^2
W = delta E
Hello,
For some reason I'm not seeing something in working out a question two ways. The question I'm working through reads:
"A 2500 kg car changes from a velocity of 15 m/s to 25 m/s over a distance of 450 m. What is the work done on the car by the engine?"
I've attached my quandry. I've surmised that the work-energy theorem can be used. Furthermore, that on the work side, I could use kinematics and on the energy side, find the change in kinetic energy. But I don't come up with the same answer on each side? This is mostly because of the difference between (vf^2-vi^2) and (vf-vi)^2. I've attached some handwritten work.
Does anyone see my error?
John
In your handwritten work, you did not calculate the change in kinetic energy correctly.
## KE_f - KE_i \neq \frac 1 2 m (\Delta v)^2##.
Very good! For some reason, I've used 1/2m(deltav)^2 in the past. This is my mistake.
Is there any use for this expression or is this completely wrong and never used?
John Mohr said:
Homework Statement:: A 2500 kg car changes from a velocity of 15 m/s to 25 m/s over a distance of 450 m. What is the work done on the car by the engine?
Relevant Equations:: W = Fd, Delta E = 1/2mdeltav^2
W = delta E
Hello,
John
Your error is that you wrote the work-energy theorem incorrectly. You have
Handwritten equation: F·d = ½mΔv², with a dot between F and d and a Δ before the v squared on the right side.
The right hand side should be the change in kinetic energy ##\Delta K= \frac{1}{2}mv_f^2-\frac{1}{2}mv_i^2##, i.e. subtract the initial KE from the final KE.
I don't know of any use for the expression ##\frac 1 2 m (\Delta v)^2##. I recommend that you trash it.:smile:
Thank you so much for your help!
@TSny @kuruman
This is crazy to realize for me. I've been teaching it this way for years and many other teachers I know teach it this way too. This video segment is a prime example. It's amazing how these things make their way into our misunderstandings.
Thanks again.
John
  • Wow
John Mohr said:
@TSny @kuruman
Thanks again.
John
Yes, the video is incorrect in the way it solved for ##\Delta v##. The final answer for ##v_f## happened to come out right because ##v_i = 0## in the example.
##\Delta (v^2)## will equal ##(\Delta v)^2## only if ##v_i = 0## or if ##v_f = v_i## (trivial).
Note that ##\frac 1 2 m (\Delta v)^2## is always nonnegative. But we know we can have situations where the KE decreases; that is, ##\Delta KE## is negative.
John Mohr said:
@TSny @kuruman
Thanks again.
John
I cannot make that link work. Just stuck on some ad that won't play.
Seems to me you confused ##\Delta(v^2)## with ##(\Delta(v))^2##.
John Mohr said:
@TSny @kuruman
This is scary, if true. What kind of teachers? Grade school teachers?
John Mohr said:
@TSny @kuruman
Thanks again.
John
On the segment you supply the instructor explicitly emphasizes that the form he wrote is good only for v(initial)=0. You should indeed be concerned.
I got a "Skip Ad" 5 s count down timer on the video lower right.
I find the interpretation of the term ##\Delta (v^2)## ambiguous. It is obvious from the context how you mean it here but, when doing error analysis, one also writes ##\Delta (v^2)=2v\Delta v##. That could be confusing to beginners who have not yet mastered the subtleties of when one uses just a "##-##" sign, a "##\Delta##", a "##\delta##" or a "##d##" to denote a difference between two quantities.
