Solving dx/dt = 8 - 3x with separation of variables and absolute values
  • Thread starter Thread starter Augustine Duran
    First order Ode
5 replies · 2K views
Augustine Duran
Solve: ##\frac {dx} {dt}## ##\text{= 8-3x , x(0)=4}##
Step 1:
##\int \frac 1 {8-3x} \, dx## = ##\int \, dt##
Step 2:
- ##\frac 1 3## ##\text{ln|8-3x| = t+c}##
From here I am going to try to get it into explicit form
Step 3:
##\text{ln|8-3x| = -3t-3c}##
Step 4:
##e^{ln|8-3x|}## = ##e^{-3t-3c}##
Step 5:
##\text{|8-3x|}## = ##e^{-3t-3c}##
im not sure what to do about the absolute values. I was thinking of cheating and just dropping them and then just solving for x which would give me
Step 6:
##\text{x= }## ##\frac 1 3####\text{(8-}####e^{-3t-3c}####\text{)}##
Plug in initial conditions x(0) = 4
Step 7:
##\text{4= }## ##\frac 1 3####\text{(8-}####e^{-3(0)-3c}####\text{)}##
Step 8: Simplify
##\text{4}##=-##e^{-3c}##
The problem here is that if i take the ln of both sides to solve for C it will be undefined because of the negative sign. Probably dropping the absolute signs in step 6 without a reason is a no no but I am not sure what to do.
Any help would be appreciated.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
What does the absolute value mean? What is |8-3x| if 3x<8 and when 3x>8? Note that you have different c-s in both cases.
You are given the initial condition, which means that 3x>8.
x(t) =
\begin{cases}
3x-8 & \text{if } x > \frac 8 3 \\
8-3x & \text{if } x \leq \frac 8 3
\end{cases}
okay so seeing that my initial conditions give me x=4 i will be using 3x-8 since 4 is larger than 8/3?
##\text{3x-8 =}####e^{-3t-3c}##
##\text{x =}####\frac 1 3####\text{(8+}####e^{-3t-3c}####\text{)}##
##\text{4 =}####\frac 1 3####\text{(8+}####e^{-3(0)-3c}####\text{)}##
##\text{12 = 8+}####e^{-3c}##
simplify
-##\frac {ln4} 3##=##\text{C}##
is this correct?
x(t) =
\begin{cases}
\end{cases}
simplify
is this correct?
Correct so far; go ahead. What is x(t)?
plugging in C and simplifying i get
##\text{x=}####\frac 8 3####\text{+}####\frac 4 3####e^{-3t}##
Of course, if you aren't required to use separation of variables, it is much easier to write it as ##x' + 3x = 8## and use the linear equation method of integrating factor. That avoids all the fuss with the absolute value signs and logarithms.
