Solving tan x - 1 = cos 2x
  • Thread starter Thread starter TheRedDevil18
    Trig
10 replies · 3K views
TheRedDevil18
tanx-1 = cos2x
I know tanx = sinx/cosx but I don't know which identity to pick for cos2x
TheRedDevil18 said:
tanx-1 = cos2x
Pick one and see if it works.
Good day TheRedDevil18
If you replace cos(2x) with 2cos2(x) - 1 ,
that will get rid of the (-1) on the left side. Then go from there...
sinx/cosx = 2cos^2(x)
sinx/cosx = 2(1-sin^2(x))
sinx/2cosx + sin^2(x) = 1
sinx/2cosx * 1/sin^2(x) = 1
2SinxCosx = 1
sin2x = 1
x = 45
All good?
What are you doing here (above)?
TheRedDevil18 said:
2SinxCosx = 1
sin2x = 1
x = 45
All good?
No.
If you check your work, you'll see that 45° is not a solution.
In addition, there probably an infinite number of solutions, unless the problem specifies that you should find only the solutions in a certain interval. Since that's not stated in your post, you need to list all the solutions.
45° satisfies the given equation but RedDevil reached it with a wrong method as you pointed out.
Thanks! He didn't show the original equation in his later work, and I misremembered cos2x as cos2x in my check.
I can't see how to solve this in an easy way. I get to
##sin(x) = 2 \; cos^3(x)##
and am stuck. I suspect something is wrong with this question.
Remember to specify interval or say "45°+ 360°(n)" as Mark44 pointed out
Go back to ##tan(x) = 2 \; cos^2(x)## and write ##cos^2## as ##1/sec^2 = 1/(1+tan^2)## to get a cubic in tan(x). One solution is obvious, the other two are complex.
RD18 turned sinx/2cosx + sin2(x) = 1 into sinx/2cosx * 1/sin2(x) = 1 instead of sinx/2cosx * 1/sin2x +1 = 1/sin2x, but got the right answer through sheer luck.
cos2x=1/(1+tan2x)
So you can write the equation as
tan3x+tanx-2=0,
rearrange: (tan3x-1)+(tanx-1)=0
factorize: The common factor is tanx-1.
ehild
