Solving the 3D Poisson equation
This discussion focuses on solving the 3D Poisson equation using spherical coordinates and spherical harmonics. The equation addressed is ##d^2\phi/dr^2 + 1/rd\phi/dr - l*(l+1)/r^2 = \rho (r)##, where ##\phi## represents the gravitational potential and ##\rho## the mass density. The user employs LU-decomposition for solving the equation and utilizes a hyperbolic transformation to manage the infinite grid. The discussion highlights challenges in setting the potential to zero at infinity and concludes with a successful solution, prompting others to share their insights.
  • Understanding of the 3D Poisson equation
  • Familiarity with spherical coordinates and spherical harmonics
  • Knowledge of LU-decomposition methods
  • Experience with hyperbolic transformations in mathematical modeling
  • Research advanced techniques for solving partial differential equations (PDEs)
  • Explore numerical methods for boundary value problems
  • Learn about potential theory in gravitational fields
  • Investigate alternative coordinate transformations for infinite domains
Mathematicians, physicists, and engineers working on gravitational modeling, numerical analysis, or anyone interested in solving complex PDEs in spherical coordinates.
debilo
TL;DR
I try to solve 3D Poisson equation with boundaries condition at infinity.
Hello !
I want to solve the 3D Poisson equation using spherical coordinates and spherical harmonics.
First I must solve this : ##d^2\phi/dr^2 + 1/rd\phi/dr - l*(l+1)/r^2 = \rho (r)## with ##\phi (\infty ) = 0## (here ##\phi## is the gravitationnal potential and ##\rho## is the mass density).
To deal with the infinite grid I tried to use the hyperbolic transformation ##r = X*arctanh(R)## with ##X## a constant and ##R## between 0 and 1.
I use a LU-decomposition method to solve this. For ##\phi (0)## I apply symmetrical conditions.
I tried to solve the problem in the case of a spherical mass distribution. I compared the calculated potential with the theoretical potential.
I find a pretty good result when I fix the value in rmax.
But for ##\phi (\infty )## I have a problem. In fact I obviously get in trouble when I let R go to 1 (or 0) ; so I take ##Rmin = 0+\varepsilon## and ##Rmax = 1-\varepsilon##.
My question is : do you know a trick to really set the value of the potential to zero at infinity ?
I finally found a solution it's ok !
Are you going to post it here? I'm sure others would be interested and they may see something you can to make it even better.
Hi, can you please post the solution?
