Solving |x²-5|=4|x|
18 replies · 4K views · last reply
MSG100
Solve |x^2-5|=4|x|.
I tried to rewrite it as:
(sqrt(x^2-5))^2=4*(sqrt(x))^2
Is this the right way to solve the equation?
MSG100 said:
Solve |x^2-5|=4|x|.
No.
For one thing, each side of the original expression exists for all values of x.
For your equation, (sqrt(x^2-5))^2=4*(sqrt(x))^2 , :
The left hand side exists only if x ≥ √(5) or x ≤ -√(5).
The right hand side exists only if x ≥ 0 .
Did you mean to apply those operations in the other order: square then square root?
That would work, but why bother square-rooting?
I make a new attempt.
I put the equation in two possible cases.
Case 1: x^2-5=4x
x^2-4x-5=0
x=5 and x=-1
Case 2: x^2-5=4(-x)
x^2+4x-5=0
x=-5 and x=1
Case 1: x^2-5=4x
x^2-4x-5=0
x=5 and x=-1
That should be x = 5 OR x = -1.
Also, you're omitting something important. In Case 1, your assumption (not stated) is that x ≥ 0. How does this assumption fit in with your solutions?
MSG100 said:
Case 2: x^2-5=4(-x)
x^2+4x-5=0
x=-5 and x=1
Same here - it should be x = -5 OR x = 1. The assumption in this case is that x < 0. How does this assumption fit in with the solutions from this case?
Of course, I meant "or" not "and"
It's just x=5 that fit in case 1
In case 2 it's only x=-5 that fit.
How do you make the assumptions?
MSG100 said:
Solve |x^2-5|=4|x|.
Since absolute-value equations can be tricky, the first step in such cases should be to plot both sides; that is, draw graphs of y = |x^2-5| and y = 4|x|, to see where they cross. That will help you to keep things straight. Be sure to make the x-range wide enough to show all the possibilities.
When you change |x| to x, you are assuming that x ≥ 0. When you change |x| to -x, you are assuming that x < 0.
One other thing is that when you change |x2 - 5| to x2 - 5, you are assuming that x2 - 5 ≥ 0, or equivalently, that x ≥ √5 or that x < -√5.
They cross at x=-5, x=-1, x=1, x=5.
Now I'm lost. The x^2 term makes it harder to get it right.
Could someone show how this should be solved or make an exemple. I can't find any similar task with the x^2 term in it. I would be very grateful.
I usually write it as three intevals, but with this I can't do that.
Make four cases (hence four intervals), since you have four different possibilities.
1. x ≥ √5
2. 0 ≤ x < √5
3. -√5 ≤ x < 0
4. x < -√5
Case 1. x ≥ √5
For the first case, since x ≥ √5, we can say with certainty that x > 0.
Then the original equation simplifies to
x2 - 5 = 4x
==> x2 - 4x = 5 = 0
==> x = 5 or x = -1
Since our assumption was that x ≥ √5, we discard x = -1.
Solution for case 1: x = 5
Now look at the other three cases.
Case 2: 0 ≤ x < √5
x has to be positive. 0 or more, but less then √5
(here I'm not sure how to use the signs)
Should it be
-(x^2-5)=4x
or
(x^2-5)=-4x
Both gives x=-5 and x=1
I did it like this:
Case 2:
-(x^2-5)=4x
Solution: x=1
Case 3:
-(x^2-5)=-4x
Solution: x=-1
Case 4:
-(x^2-5)=4x
Solution: x=-5
You can avoid all this breaking into cases. Just square both sides of the original equation to get rid of the modulus signs. This gives you a quadratic in x2. Solve. Final step is to check you have not introduced any extra solutions.
Yes, [tex]|A|=\sqrt{A^2}[/tex]
so
[tex]\sqrt{(x^2-5)^2}=4\sqrt{x^2}[/tex]
eliminate the square root by squaring both sides of the equation, and solve as haruspex suggested.
ehild
Okay, if I do so I'll get:
x^4-26x^2+25=0
and when I type it in Wolfram I get the solution:
x=1
x=-1
I made a mistake when I wrote it in Wolfram.
Now I got it right!
You don't need a calculator to figure this out. Let [itex]u=x^2[/itex], then you'll have a quadratic in u that can be factorized. Once you have two solutions for u, solve for x.
Yes, it's easy, I was outside with no pen or paper so I took some help from Wolfram.
Math becomes hard when your in a hurry.
