Why did I get x < 5 instead of x > 5 when solving 4 > 19 - 3x?
8 replies · 2K views
paulb203
Solve for x
4>19-3x
N/A
My attempt:
4>19-3x
Subtract 19 from both sides:
-15 > -3x
Divide both sides by -3:
5 > x
Switch sides (change sign):
x < 5
! But Maths Genie tells me the answer is x>5
Where have I gone wrong?
paulb203 said:
Homework Statement: Solve for x
4>19-3x
Relevant Equations: N/A
My attempt:
4>19-3x
-15 > -3x
5 > x
This is wrong. If you multiply or divide by a negative number, then you have to reverse the '>' sign. Thus it has to be 5 < x.
x < 5
You switched sign AND sides, so you didn't change anything. 5 < 6 and 6 > 5 are the same.
4>19-3x
My attempt:
4>19-3x
-15 > -3x
5 > x
x < 5
One way to find your error yourself is to check each step with numbers that should meet the inequality.
We start with ##4 > 19-3x##.
Try ##x = 4##. We have ##19 -3x = 7##, so the inequality fails.
Try ##x = 6##. We have ##19 -3x = 1##, so the inequality holds.
Your next inequality was ##-15 > -3x##.
Try ##x = 4##. We have ##-3x = -12##, so the inequality fails.
Try ##x = 6##. We have ##-3x = -18##, so the inequality holds. You are still all right.
Then you have ##5 > x##. By trying ##x = 4## and ##x = 6##, we can see that at this step things have gone wrong, and it should be ##5 < x##.
Hill said:
You did not divide by -3 correctly.
Thanks, Hill
Are you talking about the issue with the sign?
Is my division correct on its own, putting the issue with the sign to one side for the moment;
-15 / -3 = 5 ?
-3x / -3 = x ?
Yes.
“If you multiply or divide by a negative number, then you have to reverse the '>' sign. “
Ah, thanks, I think I remember this now.
Is this correct:
Example:
-15 > -18
both sides by -3
5 > 6 (incorrect, because they are now positive numbers, and 5 is obv. not greater than 6)
Is this correct:
Example:
-15 > -18
both sides by -3
Yes, exactly. The acid test is that ##x > 0## is equivalent to ##-x < 0## (multiplying or dividing both sides by ##-1##).
You have to be careful algebraically as well. The following only applies when ##a > 0##:
$$ab > ac \ \Rightarrow \ b > c \ \ \ (a > 0)$$
