Sound reflection distance and SPL in an auditorium
7 replies · 3K views · last reply
Jese Reyes
Spaker located at 90 feet from a auditorium chair. The sound pressure level at the chair is 70 dB. The first reflection from the roof takes 200ms to get to the chair.
What distance does the first reflection travel to get to the chair if the room temperature is 303.15 K?
What is the SPL of the first reflection assuming a perfect reflection from the roof?
What would the delay be of the first reflection after the direct sound has reached the chair first?
[/B]
Reflection delay = (reflected path - direct path)/ speed of sound
Reflection Level at listening position = 20 log (Direct sound/Reflection distance)
90ft = 27.432 mts
331 + .6(30C) = 349 ms This is the speed of sound at 303.15K
Solve for Rflection path 200ms= (rpath - 27.432 mts)/349 ms rpath=69800 mts does this make sense?
SPL = 20 log (27.432/6980) = -68.11 dB
Im not sure my math is making sense. I am having trouble understanding how to integrate these type of problems when calculating delays, reflection distance and SPL.
[/B]
90ft = 27.432 mts
Welcome to the PF. :smile:
First, it's important to use standard abbreviations for units, and to be careful to write them correctly. So this:
90ft = 27.432 mts
Should be this:
90ft = 27.432 m
331 + .6(30C) = 349 m/s
And this:
Should be this:
Solve for Reflection path: distance traveled in 200ms is D(200ms) = 349 m/s * 200ms = _____
90ft = 27.432 mts
Should be this:
90ft = 27.432 m
And this:
Should be this:
Thank you, i will make my future posts more accurate.
You're welcome. So what do you get for the path length, and what does that give you for the path length difference?
I get the result of 69,800 m. The difference would be 69,772.68 m. This number in my opinion is too high compared to the 90 ft distance of the speaker and chair.
That is longer than the 27.4m direct path, so that seems correct.
What does that mean? Oh wait, I thought your were using the "," character above as the decimal point (European style). If not, then 69,800m is incorrect. That calculation should give 69.8m.
Oh, I see you multiplied by 200s instead of 200ms. Note that 200ms = 0.2s (be sure to keep track of your units)
Makes complete sense! Now the numbers fit with the context of the problem. Such a small detail, i need to be more careful with my units. Thank you so much!
You're welcome, good job. And thanks for showing so much of your work -- that makes it a lot easier to catch small math errors or mistakes in unit conversions.
