Spring launching a rock: why is my calculation wrong?
13 replies · 7K views · last reply
Char. Limit
"The desperate contestants on a TV survival show are very hungry. The only food they can see is some fruit hanging on a branch high in a tree. Fortunately, they have a spring they can use to launch a rock. The spring constant is 1200 N/m, and they can compress the spring a maximum of 34 cm. All the rocks on the island seem to have a mass of 500 g."
So...
[tex]k=1200 N/m[/tex]
[tex]\Delta s = - 0.34 m[/tex]
[tex]m_r = 0.50 kg[/tex]
[tex]F_s=-k\Delta s[/tex]
So what I tried was saying that since k=1200 N/m, and s=-.34 m, then F_s=-ks=408 N. So I thought, well, this is the mass of the rock times the acceleration of the rock, right? So I did...
[tex]F_s=408 N = m_r a_s = 0.5 a_s...a_s=816 m/s^2[/tex]
Then, I tried to apply the kinematics equation...
[tex]v_f^2=v_0^2 + 2 a x[/tex]
To try to find the speed of the rock when it left the spring. So, I guessed that v_0=0, a=816-9.8=806.2 m/s^2(accounting for gravity), and x=.34 m. I plugged these values into get
[tex]v_f=23.4[/tex]
Problem is, the homework grader says it's wrong. What did I do wrong?
but that spring acceleration is only till it leaves the spring and that is not constant... 'a' by spring changes with time... so think about it again..
Oh wow, I can't believe I forgot the question.
Here it is:
"With what speed does the rock leave the spring?"
Hmm... since a isn't constant, I'm guessing that we have to do an integration here, is that right?
no, that probably isn't right.
Can we use a conservation of energy theorem here, then?
Hmm... I tried it, but it didn't work as well as I thought.
So, it should be...
[tex]\frac{1}{2} m v_f^2 + \frac{1}{2} k s_f^2 = \frac{1}{2} m v_i^2 + \frac{1}{2} k s_i^2[/tex]
So, since v_i and s_f both are 0 (I think), we get this...
[tex]\frac{1}{2} m v_f^2 = \frac{1}{2} k s_i^2[/tex]
Solving for v_f, we have...
[tex]v_f=\sqrt{\frac{k s_i^2}{m}}[/tex]
plugging in my values for those, I get v=16.66, which since the question asks for two significant figures, I rounded to v=17. But I still got it wrong for some reason.
oh forgot... if u compress the spring then leave it it goes to normal position and continues to some height... so at h=0.34 the s_f won't be 0... include this in your solution..
Hmm... I just realized, this is a vertical spring. Should I be taking gravity into account at all?
yes you should.. because that's what causes the gravitational potential energy of the ball.
OK, so I have a new question. How exactly do I find h for mgh, the gravitational potential energy?
consider the compressed place as the reference point...so the potential energy there =0... then at what height the stone leaves the contact with spring is the h for mgh.
After including gravity, I got v=16 m/s, which was correct. Thanks for the help!
