Statistic: Pattern with context dilemma
  • Thread starter Thread starter pyfgcr
    Statistic
The discussion revolves around calculating probabilities for length-3 patterns in an infinite binary text generated from specific patterns with given probabilities. Participants explore how to derive these probabilities based on the context of the patterns and their relationships.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss methods for calculating probabilities of various length-3 patterns, questioning the assumptions made about how these patterns can be formed from the original probabilities. Some suggest considering relative frequencies, while others highlight the need to account for different combinations that can generate specific patterns.
There is an ongoing exploration of the calculations involved, with some participants acknowledging previous mistakes in their reasoning. A few have recalculated probabilities based on suggestions from others, leading to new results that are being discussed. However, there is no explicit consensus on the final approach or results yet.
Participants note the importance of relative frequencies in their calculations and express uncertainty about the correct application of context in determining probabilities. There are indications of confusion regarding the generation of certain patterns and how to accurately account for them.
pyfgcr
An infinite-length binary text create from these patterns, with probability:
  • "0": 0.8
  • "11": 0.1
  • "100": 0.05
  • "101": 0.05
( For example: 0111001001010 ("0" "11" "100" "100" "101" "0") is a valid excerpt from the text)
I temporary call a,b,c,d for P("0"), P("11"), P("100"), P("101")
Problem: create a probability table for length-3 patterns (that is, find P(x): x="000","001","010",...,"111", x is excerpted at any point of the text)
Some of the patterns can be determined easily: 000, 011, 100, 101, 110 with
P(000)=a3=0.512
P(011)=P(110)=a*b=0.08
However, there are no evidence about 001,010,111. So I think of context, e.g., 001 is create with 2 "0" and anything start with 1 ("11","110","101") or 2 first zero from "100" and final 1 from anything start with 1, hence:
P(001)=a2*(b+c+d) + c*(b+c+d)=0.138
With this logic, we have:
P(010)=a*d+c*d+d*(b+c+d)=0.0525
P(111)=b*(b+c+d)+(b+d)*b=0.035
However, that logic must be applied for 000,011,100,101,110 as well:
P(000)=a3+c*a=0.552
P(011)=a*b+c*b+d*(b+c+d)=0.095
P(100)=c+(b+d)*a2=0.146
P(101)=d+(b+d)*a*(b+c+d)=0.11
P(110)=b*a=0.08
And after all, the sum of (1≤x≤8),P(x)=1.2085
I know that there is something wrong with taking the context to account, but I don't really know any other ways than considering the context.
For any bit in the sequence, there are 9 possibilities:
- the '0' in a '0' pattern
- one of the two bits in 11 pattern
- one the 3 in a 100 pattern
- one the 3 in a 101 pattern
Can you calculate the relative frequencies of these 9 cases?
Having done that, suppose you pick a bit as the first of a triplet. For each of the 9 possibilities, can you calculate the probabilities that the next two bits are 00, 01, 10, 11?
Oh, now I understand my mistake: I don't take relative frequency in account. I calculate again and now the sum is 1. Thank you very much.
pyfgcr said:
  • "0": 0.8
  • "11": 0.1
  • "100": 0.05
  • "101": 0.05
P(000)=a3=0.512
This isn't right unless I have misunderstood.
000 could be generated by ("0" "0" "0") or ("100" "0")
011 could be generated by ("0" "11") or ("100" "11") or ("101" "100") or ("101" "11") or ...
Yes, this was my mistake before, but I have calculated again with relative frequency by haruspex suggested and now the problem has been solve. The new result is 0.536, 0.134, 0.095, 0.085, 89/1500, 41/1500, 7/150, 1/60 of 000, 001, 010, 011, 100, 101, 110, 111 respectively
  • · Replies 24 ·
