Homework Helper
Dearly Missed
- Messages
- 24,752
- Reaction score
- 795
Naty1 said:...
Mix a batch of four dimensional simplicies glued together in a computer model with external independent inputs of time (arrows) (CDT), plus a cosmological constant, plus a tamed QM foam also via CDT results in a four dimensional de Sitter shape...
Naty, I was glad to see your reaction. Mine is similar in a good many respects. Your short list of ingredients doesn't mention one which is the idea of letting the size of the simplices then go to zero. (I think that's understood, in your post, but it still can use a mention.)
It is like with a Feynman path integral you might only average over all the piecewiselinear paths---polygonal paths made of short linear segments.
Then you let the lengths of the segments all go to zero.
There is a kind of practical leap of faith there (even in the original Feynman path integral) because the segmented paths are admittedly a very small subset of the set of all paths. You have to trust that they are sufficiently representative like a "skeleton crew" of the whole set. Because the whole set of paths is too big to average over. The set of segmented paths is small and simple enough so you can put a probability measure or amplitudes or whatever you need.
And then you trust that when you let the segment size go to zero the skeleton average will somehow come close to the whole average, that you can't define mathematically so well and compute with.
With Loll's method it doesn't matter very much what shape blocks they use. Only that they use some uniform set of block and let the size go to zero in the limit. They have papers using other shape blocks.
So they are not fantasizing that space is "made" of simplices or that there is any "minimal length" present in fundamental geometric reality whatever that is (there may be limits on what you can measure but presumably that's a different matter)
This is all kind of implied in what you and others were saying. So I am being a bit tiresome to be spelling it out. But it seems to me that philosophically the idea is kind of elusive. It doesn't say that the fundmental degrees of freedom are nailed down to be a certain kind of lego block. It says that a swarm of shrinking-to-zero legoblocks provides a good description of the dynamic geometry, a good skeleton path integral. That captures some important features of how space might work at small scale.
And amazingly enough deSitter space does emerge out of it, just as one would want, in the matterless case. The deSitter model is what our own universe geometry is tending towards as matter thins out and nothing left but dark energy. and it is also how you represent inflation (just a different dark energy field, but also no ordinary matter).
No amount of talk can conceal that we are not saying what is space made of. We are trying to understand a process. Spacetime is a process by which one state of geometry evolves into another state of geometry. We want a propagator that tells transition amplitudes.
There may, under high magnification, be no wires, no cogwheels, no vibrating gidgets, there may only be a process that controls how geometry evolves. It feels to me a little like slamming into a brick wall, philosophically. what if that is all there is?
