CO2 produced from NaHCO3 and CaCO3 reacting with vinegar
  • Thread starter Thread starter Mack
    Stoichiometry
19 replies · 5K views
Mack
Data Table
.........NaHC O3...CaCO3
1. Mass of micro plate.....2.05g....2.05g
2. Mass of micro plate +salt...3.05g...3.05g
3. Mass of Salt .....1g.....1g
4. Moles of salt.....1/84 mol...1/100 mol
5. Mass of unreacted setup...20.66g....17.9g
6. Mass of reacted setup.....20.58g...17.85g
7. Mass of CO2 lost......08g.....0 5g
8. Moles of CO2 lost.....0018mol...0011 mol
9. Mass of Co2 produced as % of mass of sample 8% 5%
(reacted with vinegar)
Questions:
1. Write balanced equation for each raction.
2. From the stoichiometric relationships in the data table, find the # of moles of CO2 actually produced by each reaction.
3. How did the number of moles of CO2 actually produced by each reaction compare with the number of moles that ideally should be produced?
I don’t get how to do numbers 2 and 3. I believe I did number 2 in 8 on the chart but then what is the ideall number of moles? That’s were I am confused please help
use molar mass and use the ratios from the balanced equation
:confused:
well the balanced equation would be for the CaCO3 reaction would be
CaCO3+2HC2H3O2=>Ca(C2H3O2)2+CO2+H2O
molar mass of CaCO3 is about 100g/mol and CO2 is 44g/mol
but i don't no what to do from here or what ratios u r talking about
im sry my teacher didnt explain this at all and I've called all my friends but they don't get it either
well, Ca has a charge of +2 and the acetate ion has a charge of -1, so you need to rewrite the chemical formula for calcium acetate.
you can ratio the coefficients to link any two pieces in the reaction.
example:
2H2 + O2 -> 2H2O
the ratio ofhydrogen to oxygen is 2:1. the ratio of oxygen to water is 1:2. the ratio of water to hydrogen is 2:1. does that make sense to you?
the equation isn't balanced
ya i get that so the ration of CaCO3 and CO2 is like 1:1?
well i think i know what to do but i end up with something like .44mols
and what we did in class for the lab makes out to be .0011mols
i don't get how to get how many grams of CO2 is in 1g CaCO3
if that's what I am supposed to do to get the ideal number of moles?
sry i forgot a 2 i just edited it in so its balanced now sry
can you show the work with units cause its late and i got my own ap chem final tomorrow.
read the sections called "molar ratios" and the one called "given grams get grams" - those seem like good tutorials
http://dbhs.wvusd.k12.ca.us/webdocs/Stoichiometry/Stoichiometry.html
i ment i end up with .01 not .44
what i do is i find that CO2 makes up .44g of the 1g ofCaCO3
then i divided .44g by 44g and got .01mols
when i did it in the lab only .o5g evaporated not .44g?
is the work i did correct or the lab correct?
um...its late, I am tired, those numbers appear so random to me. show all your calculations? just check the tutorials. if you can convert something to moles, you can find basically anything.
molar mass of CO2 is 44g/mol
molar mass of CaCO3 is 100g/mol
1g/100g/mol=x/44g/mol
x=.44g
.44g of CO2 makes up CaCO3?
so .44g divided by 44= .01mols?
idk I am prolly really wrong
i'm confused. what exactly happened in the lab? did you react calcium carbonate and acetic acid? then wahts "NaHC O3...CaCO3"?
the grams...grams of what? converting to moles of what?
we did it with CaCo3 and NaHCO3
it wouldn't let me space the chart out so it would scrunch it all together so i used ... to separate them if i no how to do one i can get the other easily
so you reacted each one with vinegar?
yes we reacted each on with vinegar until there was no more bubbles and found how many g of CO2 were evaporated
we used a pipet filled with vinegar and weighed it in with unreacted setup and then weighed it in with reacted setup so that only missing mass was the CO2
do you know what a limiting reagent is?
however much acetic acid used was how much reacted. base your stoich on the amount of acetic acid consumed and you should be fine. goodluck & goodnight
Mack said:
Data Table
Questions:
Start by clearly writing each reaction. You have done one already. You can abbreviate acetic acid as 'HOAc' and acetate as 'OAc-'. Calcium actate becomes Ca(OAc)2. Much cleaner, yes?
The second question is not very clearly worded. Read that as "Find the # of moles of CO2 actually produced by each reaction". I don't know how the 'stoichiometric relationships in the data table" can help (or even what it means!). There are no 'stoichiometric relationships' in the data table... only data!
The third question requires those 'stoichiometric relationships' you discovered by answering question #1 (no, those pesky relationships are not in the data table!). Rewriting your answer for the calcium carbonate reaction you have:
CaCO3 + 2 HOAc ----> Ca(OAc)2 + CO2 + H2O
Here is where you will find 'stiochiometric relationships'! You will see that for each mole of CO2 produced you will have started with one mole of CaCO3. You know the weight of the CaCO3 you started with and you can calculate the # of moles. From this you will know how many moles of CO2 you expect to find. Compare that to what you have for mass of CO2 lost (expressed in moles) in your data table.
Now, do the same thing for sodium bicarbonate...
