Subsets of Uncountable Infinite Sets
4 replies · 6K views · last reply
hetaeros
Let [tex]A[/tex] be an infinite set which is not countable and let [tex]B \subset A[/tex] be a countably infinite set.
(1) Show that [tex]A - B[/tex] is also infinite and not countable
(2) Show that [tex]A[/tex] and [tex]A - B[/tex] have the same cardinality
Hints written directly:
"Show that there is a countable subset [tex]C \subset (A - B)[/tex] and that there is a bijection [tex]g : C \cup B \rightarrow B[/tex], and try to make it into a bijection of [tex]A[/tex] with [tex]A - B[/tex]."
Here is what I have so far:
Given the hint, I am thinking that I want to use the fact that a set is infinite if there is a bijection between it and a strict subset of it. However, there's a possibility that the set [tex]C[/tex] is a finite subset, which is why I believe the professor gave us that hint about constructing a map from [tex]C \cup B[/tex] to make sure it is infinite.
Here, then is where I show that [tex]C \cup B[/tex] is infinitely countable.
Define [tex]C \subset (A - B)[/tex] as a countable subset of [tex]A - B[/tex]
Construct [tex]f : C \cup B \rightarrow B[/tex]
Since [tex]C[/tex] and [tex]B[/tex] are disjoint countable sets, their union is also countable.
[tex]B[/tex] is a countably infinite set
[tex]\Rightarrow C \cup B[/tex] is countably infinite
[tex]\Rightarrow #B = #(C \cup B) = \aleph_{0}[/tex]
[tex]\exists bijection f : C \cup B \rightarrow B[/tex]
However, this is where I get stuck. I can easily conclude that since [tex]A[/tex] is not countable, there is no bijection between and [tex]C \cup B[/tex], but that seems quite trivial at the moment, especially if I'm going to be using the theorem from above.
The part that gets me the most is how [tex]C \cup B[/tex] could possibly be a strict subset of [tex]A - B[/tex], since [tex]B \notin (A - B)[/tex]. I will probably need to use this fact that [tex]A - B[/tex] is infinite, but I am completely lost as to how to go about this.
To prove that [tex]A - B[/tex] is also uncountable: will I need to show that there cannot exist a bijection between it and [tex]C \cup B[/tex] ? The funny thing about this is that if [tex]A - B[/tex] is infinite, it must have a bijection between it and [tex]C[/tex], which is where the whole issue with [tex]C \cup B[/tex] turns almost circular.
Can someone please help me clear things up and perhaps find a better strategy for a proof?
As per part (2), I would assume that the easiest way to do this is to show that there exists a bijection between [tex]A - B[/tex] and [tex]A[/tex]. Would the results of the previous part be required to solve this?
Thank you for your time--any help would be greatly appreciated!
For part (1), just notice [tex](A-B) \cup B[/tex] = A, and the union of two countable sets is countable.
For part (2), you (should) know there is a countable subset C of A-B. This is useful to know. When making your bijection from A to A-B, try separating it into the case of whether an element of A is in (A-B)-C or not.
Ah, but we're trying to prove that [tex](A - B)[/tex] is uncountable.
Office_Shredder is gently suggesting a proof by contradiction. If (A-B) were countable then so would (A-B) union B. But that's A. And it's not countable. Hence A-B is uncountable.
Ah, I see. The contradiction comes from the fact that the given A is uncountable.
