Tachyons travel backward in time?
  • Context: Graduate
  • Thread starter Thread starter CJames
    Time Travel
71 replies · 46K views
RandallB said:
No this is not what simultaneity means!
Any one frame can ignore all other frames and show separated simultaneous events and get usable answers as long as it never uses a value defined in some other frame. Simultaneity says that the simultaneous space like separated results you find using such a “preferred frame” cannot be understood as actually being simultaneous.
What does "actually simultaneous" even mean? No one is claiming that there is any absolute simultaneity involved, each frame uses its own distinct definition of simultaneity, and all frames are equally valid as far as physics goes. "Preferred frame" is used to denote the notion of a frame where the laws of physics take a different, preferred form than in other frames (like in the old aether theories where light would only move at c in all directions in the rest frame of the aether, in other frames its speed would be different in different directions), but I'm in no way using such a preferred frame. The whole argument about tachyons is based on the idea that the laws of physics governing tachyons should work the same way in every frame, so if you can show that tachyons move instantaneously or backwards in time in terms of one frame's definition of simultaneity, it must be possible for tachyons to move instantaneously or backwards in time in terms of every frame's definition of simultaneity. If you deny this, and say tachyons can behave this way in some frames but not others, then it is you who are postulating a preferred frame!
RandallB said:
Sure even Einstein uses the word simultaneous within individual frames for SR speed problems such as trains and embankments. That is how he illustrated getting to the conclusion that simultaneous events in one frame were not simultaneous in the other frame. Likewise simultaneous events in the other frame were shown to not be simultaneous in the first.
From that Einstein established the principle of simultaneously, in order to maintain a consistent set of physics laws usable in all frames of reference. The simple rule of simultaneity is that simultaneous events within a single reference frame cannot be considered as actually being simultaneous - That's It!
What does "actually being simultaneous" mean? If you're suggesting that there is some absolute truth about whether events are simultaneous, which is different from the definition of simultaneity used by a particular frame, that's the opposite of what Einstein was trying to show. If you're just saying that there is no absolute definition of simultaneity, that we can only talk about "simultaneity" relative to a particular frame but that all frames are equally valid, then I agree entirely, that's what I've been saying all along. And if you combine that with the first postulate which says the laws of physics must work the same way in every frame, then if it's possible to send tachyon signals which move instantaneously or backwards in time according to one frame's definition of simultaneity, then it must be possible to send tachyon signals which move instantaneously or backwards in time according to any other frame's definition of simultaneity too.
RandallB said:
Now you and Jesse seem to think that simultaneity can be used to identify the correct time for tachyon in absolute values well enough to when it reached a distant point to know realtive to local time.
What are you talking about? I never said anything about absolute values. I just said when the tachyon departs and when it arrives using a particular frame's coordinate system.
What do you mean by "local time" anyway? Do you mean something different than "the time in a particular frame"? After all, frames of reference in SR are not "local" to a particular region, they are coordinate systems that describe events throughout the entirety of spacetime.
RandallB said:
If either of you could do that, then I have simple challenge one of you should be able to solve – no tachyon needed. If you can do it for tachyons, this should be easy.
Use Jesse’s problem where the other frame moves at 0.6c with observers at x= 0 & 10 and x’ = 0 & 5.
Do the math to be sure we all agree on the fallowing three sets of truly simultaneous events based on SR simultaneity rules:
A: x = 0 correctly observes a flash of light (following the tachyon) start off at t=0
simultaneously x’ = 0 sees the same flash start at t’=0
B: x =5 meets x’ =0 at t=8 1/3
Yes, that's right, x' = gamma*(x - vt) = 1.25*(5 - 0.6*8 1/3) = 1.25*(5 - 5) = 0
RandallB said:
simultaneously x’= 0 meets x = 5 at t’ = 6 2/3
Yes, it's correct that x'=0, t'=6 2/3 in the primed frame has spatial coordinate x=5 in the unprimed frame, since:
x = gamma*(x' + vt') = 1.25*(0 + 0.6*6 2/3) = 1.25*4 = 5. And it's also true that
t = gamma*(t' + vx'/c^2) = 1.25*(6 2/3 + 0.6*0) = 8 1/3.
So, all you're really saying here is that the event with coordinates (x=5, t=8 1/3) in the unprimed frame has coordinates (x'=0, t'=6 2/3) in the primed frame. These aren't two simultaneous events, it's just a single event that is assigned different coordinates in the two coordinate systems.
RandallB said:
C: x = 10 sees the flash of light arrive at t = 10
simultaneously x’ = 5 sees the same flash arrive at t’ = 5
Again, this is just the same event assigned different coordinates in the two coordinate systems, not two simultaneous events...but yes, your numbers are correct again.
RandallB said:
When did the simultaneous C events occur before or after simultaneous B events ?
Observer x = 5 claims before as do all other x observers while x’=0 claims after as do all other x’ observers!
Sure. What's the problem here? Since B and C are spacelike separated (neither event lies within the other event's light cone), different frames can disagree on which event happened first and which happened second. That's just a standard feature of relativity. However, without tachyons no physical signal can travel between B and C, so there's no frame that sees information going FTL or backwards in time.
RandallB said:
If either of you can solve this using SR and simultaneity, without a preferred reference frame. I will issue an apology and a retraction.
I don't understand what you mean by "solve this". It's an accepted fact that because different frames disagree about simultaneity, they can also disagree about which of two spacelike separated events happened earlier and which happened later. Do you disagree that this is an accepted fact? If you do disagree, I can quote various sources on SR which point this out. And if you agree that this is widely accepted, then again, what's the problem?
RandallB said:
But I expect an unambiguous definitive answer for one or the other before or after!
Again, if you think I'm claiming there's some sort of absolute truth about simultaneity, you've got my argument completely backwards. Simultaneity is relative to one's choice of reference frame. For any single tachyon signal, different frames disagree about whether it's going forward in time or backward in time, and there is no absolute truth about this. The point is that if you have a frame A where a tachyon signal is going FTL but forwards in time and another frame B where it's going backwards in time, then by the principle that anything which is physically possible in one frame must be physically possible in all frames (the first postulate of relativity), it must be possible to send a second tachyon signal in reply to the first which is going FTL but forwards in time in frame B, and backwards in time in frame A. With the combination of the two signals, you can arrange things so that the event of an observer receiving the reply actually happens in the past light cone of the event of the same observer sending the original tachyon signal, so in this case all frames agree that the reply was received before the first signal was sent (these two events have a timelike separation rather than a spacelike one, meaning there can be no disagreement about their order).
DaleSpam & JesseM you guys got some es’planen’ to doo
DaleSpam said:
You seem to have some mistaken notions about the concepts "simultaneous" and "prefered". The fact that two given spacelike separated events happen to be simultaneous in a given frame in no way makes it a "prefered" frame. It may be "prefered" in the sense that some computations are easier to carry out in that frame, but not in the usual sense that the laws of physics are in any way different in that frame.
RandallB said:
A: x = 0 … observes a flash of light (following the tachyon) start off at t=0
First, C=(10,10) is the same event as C'=(5',5'). They are not separate events, they are the same event written in the coordinates of different reference frames. Similarly with A=(0,0) and A'=(0',0') and B=(8.33,5) and B'=(6.67',0'). Remember, events are the spacetime equivalent of points. A point does not become two points simply because you can write it in two different coordinate systems.
Do I really need to spell this out as if you were a fifth grader?
The C event is a set of observations made by a single observer located at x=10 including 1.getting nose to nose with another observer located at x’=5 with a clock on display 2. Receiving enough photons from two clocks in the local vicinity to make note of t=10 and t’=5 on those two clocks. 2. observing enough photons from a flash of light to indentify it as the flash starting at simultaneous events A & A’.
The C’ event is another set of observations made by a completely different observer in another reference frame. Collecting a differ group of sampling photons, confirming the same information about getting nose to nose, times on a couple clocks, and a flash of light that has just appeared.
Likewise I take B & B’ to be a pair of events as are A & A’, each pair being "actually simultaneous” paired events with no spacelike separation between the two. [I have no problem with using a four variable description of these pairs as (x,t,x’,t’) but the two variable (x,t) or (x’t’) for each separate event is no less a complete description for where both events occurred.]
JesseM asks “What does "actually simultaneous" even mean?”
That means for the above three pairs of events is that not only does each pair appear simultaneous in the x & x’ frames; but as they are not space like separated they will be “actually simultaneous” as measured by any and every other possible reference frame you might come up with. (Try if you like).
It also means, Einstein simultaneity tells me that apparent same time events with spacelike separation such as t=0 for x= 0, 5, & 10 within a frame, CANNOT be considered to be "actually simultaneous" even if I live on that frame no matter how weird in might seem to me.
Obviously you and JesseM disagree with me which being us to your second sentence:
“The fact that two given spacelike separated events happen to be simultaneous …”[\b]
Clearly you and JesseM feel that it is possible find a case where spacelike separated events in a common reference frame are “actually simultaneous”.
Such as when JesseM concludes that the x' = 117.5 t' = -62.5 is “actually simultaneous” with x’=0 t’= -62.5 and therefore the tachyon would have ended at x’ = 117.5 before it started at x’=0
Neither of you need to convince me of the tachyon example,
just one of you show us you have the math to demonstrate any two space like separated in a reference frame such as t = 10 for x = 5 and 10 “actually simultaneous”. Meaning that any and all other reference frames will either agree they are simultaneous OR if any alternate frame disagrees you have math convincing to observers in such other frames the their observations are wrong and your evaluation of the two events as simultaneous is correct.
If you can do that in the nonFTL case I will accept your applying whatever math you are using in the FTL case.
But if your appoch cannot be confirmed in the nonFTL case I’ll never accept in the FTL example.
OK, I see why you referred to two events here. I was confused because it isn't really necessary to have an observer right next to an event and at rest in a given frame in order to assign coordinates to that event in the frame. For example, if I see an event 10 light years away in my rest frame, I can just use the fact that light moves at c in my coordinate system, and conclude that the event happened at a time-coordinate 10 years earlier than the time on my watch when I saw it.
But we can do it your way--in this case we can imagine an observer at rest in the C frame at position x=10 in that frame, and we can imagine another observer at rest in the C' frame at position x'=5 in that frame, and the two will meet at exactly the moment that the light reaches them. So we really have three events here--the event of the first observer's clock ticking t=10, the event of the second observer's clock ticking t'=5, and the event of the light being detected at that point in space. But note that it's not as if specific events require specific coordinate systems to describe them--as long as these events have zero spatial and temporal separation between them, we would say that the event of the of the first observer's clock reading t=10 has coordinates t'=5 in the C' frame, and likewise the event of the second observer's clock reading t'=5 has coordinates t=10 in the C frame. Would you agree?
When you say "three pairs of events" are you referring to the paragraph below? (I put '3' in italics because you actually wrote '2' there, but I think you meant to write '3')
The C event is a set of observations made by a single observer located at x=10 including 1.getting nose to nose with another observer located at x’=5 with a clock on display 2. Receiving enough photons from two clocks in the local vicinity to make note of t=10 and t’=5 on those two clocks. 3. observing enough photons from a flash of light to indentify it as the flash starting at simultaneous events A & A’.
If we assume the spatial and temporal separation between these events is infinitesimally small (assuming pointlike observers, and assuming the observations are all made at precisely the time the spatial separation between them reaches zero) then these events are simultaneous in every frame. After all, in the C frame all six events have precisely the same coordinates (x=10, t=10), and in the C' frame all six events have precisely the same coordinates (x'=5, t'=5). And if you plug some new velocity into the Lorentz transform, you'll still find that these six events all have the same coordinates in your new frame. "Same coordinates" means "same time coordinate", so no matter what frame you pick, all six events happen simultaneously in that frame. But this is only because the spatial and temporal separation between the events is zero--if there is any nonzero spatial separation [tex]\Delta x[/tex] or a nonzero temporal separation [tex]\Delta t[/tex] between two events in any given frame, then all frames cannot agree they are simultaneous. In the case where the spatial separation or the temporal separation between events is nonzero, then if the spacetime separation between two events is timelike ([tex]c^2 \Delta t^2 - \Delta x^2 > 0[/tex]) or lightlike ([tex]c^2 \Delta t^2 - \Delta x^2 = 0[/tex]) in a given frame, then all frames will agree the events happened at different times, and all frames will agree on which happened first, while if the spacetime separation between the events is spacelike ([tex]c^2 \Delta t^2 - \Delta x^2 < 0[/tex]) then one frame will say the events were simultaneous, while other frames will say they happened at different times but disagree about which happened first and which happened second. Is there any of this you disagree with?
I have never argued that events can be "actually simultaneous" as you define it (all frames agreeing they are simultaneous), except in the special case where both events happened at the exact same point in space and time (zero spatial separation and zero temporal separation). Do you think I have ever argued that events at different points in spacetime like (x=0,t=0) and (x=5,t=0) and (x=10,t=0) can be "actually simultaneous"? If so, what quote of mine lead you to believe I was saying that? I have been saying the exact opposite, that simultaneity is relative to your choice of reference frame (again, assuming we're talking about events with a separation between them), that events which are simultaneous in one frame will be non-simultaneous in others, and there is no "real truth" about the matter. For example, in post #58 I said:
in relativity each frame has its own definition of simultaneity (which is just the same thing as happening at the same time-coordinate in that frame), and no frame's definition is more "true" in any absolute sense than any other's.
...and then provided numerous quotes from authoritative sources to back it up. I thought you might have been arguing that there is a "real truth" about simultaneity, which is why I did that...are you saying you agree that there is no frame-independent truth?
Here you seem to be quoting DaleSpam in post #60 where he writes:
So clearly he is talking only about simultaneity relative to a particular frame, not absolute simultaneity. Again, can you provide a quote from either of us that claims separated events can be "actually simultaneous" in a frame-independent sense, as opposed to just being simultaneous relative to a particular frame?
No, I believe nothing of the sort. I really have no idea what lead you to believe I was arguing that.
Uh, I never said anything like that either. These events are only simultaneous in the C' frame which uses these coordinates, so the tachyon was received before it was sent in that frame, while in other frames it was sent before it was received. The only case in which you have information going backwards in time in all frames is when you send two tachyon signals, in the manner I described at the end of that post:
Let me give a numerical example of this to make it more clear. Suppose we have an observer Alice at rest at position x=0 in the C frame, and another observer Bob at rest at x'=0 light-seconds in the C' frame, and moving at 0.6c in the +x direction relative to the C frame. Say Alice and Bob start out at the same position at x=0 in the C frame and x'=0 in the C' frame. So at a time of t=156 2/3 seconds in the C frame, Bob will be at position of x = 156 2/3*0.6 = 94 l.s. in the C frame. Now suppose that at t=156 2/3 seconds, Alice sends a tachyon signal which moves at 10c in the C frame, so that 10 seconds later at t=166 2/3 seconds, the tachyon signal has reached position x=100 l.s. In those 10 seconds, Bob has moved an addition 6 l.s. in the C frame, so he will arrive at x=100 l.s. at the same moment.
So, the event of Bob receiving the tachyon signal happens at x=100 l.s., t=166 2/3 s in the C frame. What about Bob's own rest frame C'? In this frame the event has coordinates:
x' = 1.25*(100 - 166 2/3*0.6) = 0
t' = 1.25*(166 2/3 - 100*0.6) = 1.25*(106 2/3) = 133 1/3
Also, in Bob's frame C' Alice has been moving in the -x' direction at 0.6c since their positions coincided at t'=0, so at t'=133 1/3 her position in this frame is x' = -0.6*133 1/3 = -80 l.s.
Now, suppose at this same moment of t' = 133 1/3 when Bob receives the tachyon signal from Alice, Bob immediately sends a tachyon reply which moves at 10c towards Alice in his frame (this is where the first postulate of relativity comes in--if it's possible to send a signal at 10c in the coordinates of one frame, it must be possible to send a signal which moves at 10c in another frame). After about 8.5106383 seconds in the C' frame, at time t' = 133 1/3 + 8.5106383 = 141.84397, the tachyon signal catches up to Alice, since it is now at position x' = -10*8.5106383 = -85.106383, and meanwhile she has moved -0.6*8.5106383 = -5.106383 so her new position is also x' = -80 - 5.106383 = -85.106383. So, the coordinates in the C' frame of Alice receiving the reply are x' = -85.106383, t'=141.84397.
Now go back to Alice's frame and see when she receives the reply. Again, this can be done with the Lorentz transform:
t = 1.25*(141.84397 + 0.6*-85.106383) = 1.25*(90.78014) = 113.4752 seconds.
And of course, since Alice is always at the origin in her coordinate system, the position of this event is:
x = 1.25*(-85.106383 + 0.6*141.84397) = 0
Anyway, the thing to note is that the event of Alice receiving Bob's reply actually happened earlier in Alice's frame than the event of her sending the original tachyon signal at t=156 2/3 seconds! She actually received Bob's reply before she sent her first message, so if Bob had just replied by sending her message back to her, she'd know what message she was going to send before she sent it. And the event of Alice receiving Bob's reply has a timelike separation from the event of her sending the message, so all inertial frames agree on the order of these two events.
I have never, ever argued that events with a spacelike separation can be "actually simultaneous" in the way you describe, and neither has DaleSpam as far as I can tell. Both of us have consistently said that simultaneity is relative to a particular frame of reference--each frame has its own judgment about whether two events are simultaneous.
Seems to me you have just failed to understand the actual argument, and that the argument you imagine that I and DaleSpam are making has no resemblance to what we were really saying.
Don’t have time to review your entire post but here is the important part you need to address
But yes you did, see your post #53;
JesseM said:
It's because of the relativity of simultaneity ...
So you can see that in this coordinate system, the tachyon was received a full 62.5 seconds before it was emitted. ...
If you agree that it's possible for a tachyon to be received before it's emitted in some frame, ...
I don’t agree because you keep declaring that apparent simultaneous time observations at spacelike separations in x’ can be considered as real simultaneous events per simultaneity – thus you say the t’ of -62.5 at x’ = 117.5 is simultaneous with with the t’ = -62.5 for x’=0 and therefore Before the start.
If you did not make this assumption (a preferred frame assumption by the way) explain exactly how you decided the x’ = 117.5 arrival happened before the x’=0 start?
Obviously those results give the appearance of “backwards” time to x’ observers. BUT IT DOES NOT give that appearance to them if they apply the rules / understanding of SR simultaneity!
You guys seem to think “simultaneity” says something like “you may consider same time events within a common frame to be simultaneous”! Or as you put it “that simultaneity is relative to your choice of reference frame”!
That could not be more wrong, SR says nothing of the sort nor is it a part of “the way the Lorentz transform works”. Simultaneity applies uniformly the same in any frame of reference as any physics rule should. It says that those observers in order to truly understand the reality of their own reference frame must recognize that spacelike separated common time events cannot automatically be considered simultaneous! Additional, SR cannot and is not the tool to establish any two spacelike separated as being simultaneous.
Dang, that makes it hard to use, how can astrophysicists get any work done!
They make an assumption!
A non SR, let's ignore Simultaneity for a special case inside a few thousands of light-years around ( more if we can get by with it). You cannot call such a departure from SR “relativity” and they don’t – it’s called Astrophysics as they presume to establish a preferred reference for at least a local region of space (but often much larger) based on the CMBR. (Particale Physics doesn’t need or use such a device AFAIK)
...And by the way SO DID YOU!
When you started the problem in post # 53 you made it clear that the tachyon was ten times faster than light, and it was clear you intended that to mean after t=10 light and the tachyon would simultaneously reach x=10 and x= 100. Unless you make it clear that those two events may not be simultaneous, and how you proceed with that fact included you simply cannot assert that you did not start without a preferred frame assumption.
Frankly IMO you cannot even state the problem without making that assumption.
And once you do it is exclusive, no other frame can be considered preferred and all time ordering issues must be converted the one preferred frame. That means you cannot draw conclusions from the t’ observations as you did.
So unless you can state clearly how you avoided using preferred frames and still defined which space like separated events happened when relative to a single observer like at x’=5 or x=10 your example is pointless.
But by sticking with your original preferred frame I can state the following.
Tachyon and Light starting at t=t’=x=x’=0 arrived simultaneously at t=10 at locations x=100 and x=10 respectively in the preferred frame.
Additionally the t’=5 at x’=5 is simultaneous with t’ = -62.5 at x’ = 117.5
However if you were using some level of science beyond what Astrophysics uses, now is the time to spell it out
RandallB said:
DaleSpam & JesseM you guys got some es’planen’ to doo.
Yes, I suppose we do have some explaining to do as you are woefully ill-informed about some basic terminology and concepts in SR. However, I will leave the long explanatory posts to JesseM since I do not have the energy or patience to educate you properly.
Please spend the time and effort to learn the basic concepts (spacetime, event, Lorentz transform, simultaneous, Minkowski diagram, spacetime interval, timelike, and spacelike) for yourself, and then come back and see if these comments make more sense.
I really don't understand how you think these quotes mean I'm saying events are "actually simultaneous" (which you define as meaning not just simultaneous in one specific frame, but rather 'they will be “actually simultaneous” as measured by any and every other possible reference frame you might come up with') when the parts in bold show quite clearly I am talking about simultaneity relative to a specific frame only. Seriously, can you explain your reasoning? Is there something I'm missing about your definition of "actually simultaneous", or do you think it's somehow incorrect to talk about simultaneity in a specific frame (as I showed with my quotes in post #58, real physicists, including Einstein, talk this way all the time, it's just standard terminology to say that events which have the same time-coordinate in one frame are 'simultaneous' in that specific frame).
What does "real simultaneous events per simultaneity" mean? I always talk about relative simultaneity, not absolute or "real" simultaneity, which is eliminated altogether in relativity. This is how all physicists use the term "simultaneity", did you not read those quotes in post 58?
Sure, those two events are simultaneous in the primed frame. They are non-simultaneous in the unprimed frame. There is no single fact about whether or not they are "really" simultaneous, relativity rejects all notions of "real" frame-independent simultaneity.
It happened before the start in the primed frame, and after the start in the unprimed frame. Neither one represents any sort of frame-independent "actual" truth, they are both statements that are specific to a particular frame, and relativity says all frames are equally valid.
If there is only a single tachyon signal, I agree that it does not move "backwards in time" in any objective frame-independent sense, so there is no causality violation here. But that is why I keep saying over and over (and you keep ignoring it) that the key is to have two tachyon signals, an original and a reply, with the first signal moving FTL but forwards in time in frame #1 (and backwards in time in frame #2), and the second signal moving FTL but forwards in time in frame #2 (and backwards in time in frame #1). The end result is that the event of the first observer receiving the reply happens before the event of his sending the original signal, and there is a timelike separation between the event of his receiving the reply and the event of his sending the original signal, so all frames do agree on the order of these two events, and this is a genuine causality violation. If you think this reasoning is wrong, please address the numerical example with Alice and Bob that I gave near the end of post #63.
"As any physics rule should"? Do you think velocity applies uniformly the same way in any frame of reference too, so that if I am at rest in one frame I must be at rest in all frames? That isn't true even in Newtonian physics! Anyway, if you honestly disagree that it's standard practice to give each frame its own different definition of simultaneity, look over the quotes from real physicists that I gave in [url=https://www.physicsforums.com/showpost.php?p=1603331&postcount=58[/URL]. When Einstein writes "Events which are simultaneous with reference to the embankment are not simultaneous with respect to the train, and vice versa (relativity of simultaneity)", do you think he is agreeing with you or with me? When A.P. French writes "An immediate consequence of Einstein's prescription for synchronizing clocks at different locations is that simultaneity is relative, not absolute ... Our judgment of simultaneity is a function of the particular frame of reference we use", do you think he's agreeing with you or me? And when John Wheeler and Edwin Taylor write "Did the two lightning bolts strike the front and the back of the train simultaneously? Or did they strike at different times? Decide! Strange as it seems, there is no unique answer to this question. For the situation described above, the two events are simultaneous as measured in the Earth frame; they are not simultaneous as measured in the train frame. We say that the simultaneity of events is, in general, relative, different for different frames." -- do you think they are agreeing with you or me?
[quote=RandallB]It says that those observers in order to truly understand the reality of their own reference frame must recognize that spacelike separated common time events cannot automatically be considered simultaneous![/quote]
So when you say "cannot automatically", you are claiming that there [i]is[/i] some truth about "actual simultaneity", so that there would be a specific frame where events that have the same time coordinate in that frame actually [i]are[/i] simultaneous? This is the exact opposite of what relativity claims, and if you insist on this without being willing to consider the possibility you might be misinformed or to address the numerous quotes from professional physicists which say the opposite, then I really think this should be reported to the moderators, because you're violating the rules [url=https://www.physicsforums.com/showthread.php?t=17355]here[/url] about not arguing about relativity's validity or endorsing your own personal theories, this sort of thing can mislead people who come to these forums trying to learn about mainstream physics.
[quote=RandallB]Dang, that makes it hard to use, how can astrophysicists get any work done!
They make an assumption![/quote]
No, they pick a particular coordinate system to work in, without granting that coordinate systems' judgments about simultaneity any special truth, just like they use the velocities of galaxies in a particular coordinate system without claiming that our galaxy is "really" at rest or that distant galaxies are "really" moving at close to the speed of light.
[quote=RandallB]When you started the problem in post # 53 you made it clear that the tachyon was ten times faster than light, and it was clear you intended that to mean after t=10 light and the tachyon would simultaneously reach x=10 and x= 100. [/quote]
Only in that frame. In other frames these events would be non-simultaneous. Simultaneity is relative to your choice of frame, just like velocity.
[quote=RandallB]Unless you make it clear that those two events may not be simultaneous, and how you proceed with that fact included you simply cannot assert that you did not start without a preferred frame assumption.[/quote]
No preferred frame assumption, because I didn't say anything about these events being simultaneous in other frames, or about this frame's perspective being any more valid than any other frame's perspective. If I said some object's velocity was 0.8c in a particular frame, would you assume I was making the claim that it had an absolute velocity of 0.8c which all frames would have to agree on?
[quote=RandallB]Frankly IMO you cannot even state the problem without making that assumption.
And once you do it is exclusive[/quote]
I don't need to make any assumptions about absolute simultaneity or preferred frames at all. You are really completely confused here.
[quote=RandallB]So unless you can state clearly how you avoided using preferred frames[/quote]
I avoided using preferred frames because I said nothing whatsoever that would lead a person with understanding of SR to imagine I [i]was[/i] postulating a preferred frame, or doing anything other than making frame-specific claims about simultaneity. But you apparently lack even a basic understanding of the way simultaneity works in SR.
[quote=RandallB]But by sticking with your original preferred frame I can state the following.
Tachyon and Light starting at t=t’=x=x’=0 arrived simultaneously at t=10 at locations x=100 and x=10 respectively in the preferred frame. [/quote]
The frame is not "preferred". It is just the frame I started out working with, where the tachyon has a speed of 10c and these two events; I can and did show that in a different, [i]equally valid[/i] frame the tachyon's speed is different, and these events are non-simultaneous.
[quote=RandallB]Additionally the t’=5 at x’=5 is simultaneous with t’ = -62.5 at x’ = 117.5 [/quote]
In the unprimed frame these events are simultaneous. In the primed frame they are non-simultaneous. Simultaneity is relative to your choice of frame in relativity, hence the phrase, "relativity of simultaneity".
[quote=RandallB]However if you were using some level of science beyond what Astrophysics uses, now is the time to spell it out[/QUOTE]
Only in your ignorant fantasy version of astrophysics is there any objective, frame-independent truth about whether different events are simultaneous or not. I'm sure you've never taken an actual course or studied the mathematical details, because if you had, you'd know that simultaneity in astrophysics is every bit as coordinate-dependent as velocity in astrophysics, there is no frame-independent "objective truth" about either one.
JesseM said:
But unless these two hypotheses lead to different predictions, this is not a question that can be addressed by physics, any more than the question of which "interpretation" of quantum mechanics is correct.
What theoretical argument leads you to believe that something "moving backward in time" would be gravitationally repelled by normal matter? In any case, see here and here for some info on the gravitational properties of antimatter.
Sorry for not replying earlier. It seems obvious to me that if gravity is _solely_ an attractive force, but antiparticles are actually moving backwards in time, then the attraction would happen in reverse time, causing the appearance of a repulsion.
Conversely, if antimatter and normal matter gravitationally repel one another, and antiparticles move backwards in time, then antiparticles would appear to be gravitationally attracted to normal matter in normal time.
Actually, gravity is time-symmetric, meaning the laws of gravity are unchanged under a time-reversal transformation--in physical terms, this means that if you look at a film of objects moving under the influence of gravity, there's no way (aside from changes in entropy) to determine if you're watching the film being played forwards or if it's being played backwards. The reason it seems asymmetric is because of entropy, like how a falling object will smack the ground and dissipate most of its kinetic energy as sound and heat--if a falling object had a perfectly elastic collision with the ground so that no kinetic energy was dissipated in this way, each time it hit the ground it would bounce back up to an equal height as before, so this would look the same forwards as backwards (and the reversed version of the collision where kinetic energy is dissipated is not ruled out by the laws of physics, it's just statistically unlikely that waves of sound and the random jostling of molecules due to heat would converge to give a sudden push to an object that had been previously been resting on the ground...if it did happen, though, it would look just like a reversed movie of an object falling to the ground and ending up resting there). Likewise, any situation where no collisions are involved, like orbits, will still be consistent with the laws of gravity when viewed in reverse.
Well JesseM is already disagreeing with you about the definition of “event”.
Why not start your explaining with the one you left out, simultaneity.
I put up mine: “… Einstein simultaneity means that apparent same time events with spacelike separation within a frame, CANNOT be considered to be "actually simultaneous" even if I live on that frame no matter how weird in might seem to me.”
To be applied as is, in any reference frame you find.
JesseM put up his:
“ … each frame uses its own distinct definition of simultaneity, and all frames are equally valid as far as physics goes.”
Thus each frame has a difference set of physics laws as each has a “distinct definition of simultaneity”. A concept my definition of simultaneity does not support.
We both read the same Einstein but reach different opinions of what “simultaneity” means.
So where is your definition and of the above which is correct.
What do you use to support it, other than repeating whatever JesseM says?
In other words Sir Spam, put up or shut up.
JesseM said:
I really don't understand how you think these quotes mean I'm saying events are "actually simultaneous" (which you define as meaning not just simultaneous in one specific frame, but rather 'they will be “actually simultaneous” as measured by any and every other possible reference frame you might come up with') when the parts in bold show quite clearly I am talking about simultaneity relative to a specific frame only . Seriously, can you explain your reasoning?
Explain mine! How on Earth do you justify yours, with different rules of physics in differ frames! Just try to find a reputable resource that defines simultaneity as you do. There are perceived observations of simultaneous spacelike separated events relative to a specific frame only . But there is no such thing as “talking about simultaneity relative to a specific frame only ”.
I avoided using preferred frames because I said nothing whatsoever that would lead a person with understanding of SR to imagine I was postulating a preferred frame,
So when you say "cannot automatically", you are claiming that there is some truth about "actual simultaneity", so that there would be a specific frame where events that have the same time coordinate in that frame actually are simultaneous?
Are you dense? Did you read what I said simultaneity means. The only way to declare spacelike separated events as “actually simultaneous” is to make assumptions outside those allowed by SR & the principle of simultaneity. I was very clear on that!
And more than simultaneous it also includes declaring you can tell from inside a single reference frame if an event happened before or after some other space like separated event Which is exactly what you did!
And I are you really so dense as to not recognize you used two different preferred frames to do it! There might be some cases where you can make the assumption of using a preferred frame outside the SR rules, but no one can justify using two different preferred frames in the same problem as you do.
Some of the most ignorant comments I’ve ever seen. Is there any clearer evidence that you are using a preferred frame when you declare “In the unprimed frame these events are simultaneous”! Again, simultaneity is clear you cannot say those events “are simultaneous”, you can only say that they appear to be simultaneous only from within the frame. As I’ve said before you’ve been around long enough to know better than this, yours is some of the worst misinformation I’ve ever seen on simultaneity. Maybe it should be reported.
In any case this is my last post here I am unsubscribing from this thread, I’ll not participate in your nonsense any longer.
If you two are able to convince others that your “backward time” assumptions can be supported by “Einstein Simultaneity” so much the worse for the credibility of these forums.
There are no different "rules of physics", just different answers to frame-dependent questions like "what is the velocity of this object" or "are these two events simultaneous".
What does that mean exactly? Are you saying the events "really are" simultaneous, but different frames have different perceived observations of these events? Or are you saying that different frames have different opinions about whether they are simultaneous, and that there is no single objective truth about whether or not they "really are" simultaneous? If the former, then you're suggesting there is such a thing as absolute simultaneity, which is forbidden by relativity. And if the latter, then how is that different from "talking about simultaneity relative to specific frames"?
Sure there is. In Einstein's thought-experiment with the trains, you can talk about simultaneity relative to the frame of the train, or you can talk about simultaneity relative to the frame of the embankment, just as Einstein himself did. (I note you continually ignore these quotes I posted--perhaps you realize they undermine your position?) Both ways of talking are equally valid. You can't talk about simultaneity without specifying which frame you're referring to, though--that's what I meant by "simultaneity relative to a specific frame".
Yes, and it seemed like you were saying that in astrophysics, physicists do make assumptions outside of the SR notion of simultaneity, so that astrophysicists can decide whether events are "actually simultaneous". If you did mean this then you're totally wrong, simultaneity is still relative in astrophysics. If you didn't mean this, then please explain what you were talking about when you said:
You seem to be accusing me of saying that "from inside a single reference frame" I can determine some objective truth about whether one spacelike separated event happened before or after another one. But I'm saying the opposite, there is no objective truth about which of two spacelike separated events happened before the other one, this question is frame-dependent just like the question of which of two objects has a higher velocity than another one (from the perspective of either object's rest frame, it is the other object that has a higher velocity, and both frames are equally valid). Do you disagree? Do you think there is a single objective truth about which of two spacelike separated events happened before the other one?
I used zero preferred frames, silly. I just talked about the judgment of simultaneity in each frame--just like Einstein and other physicists did in the quotes I gave you--but I didn't say either frame's judgments were to be preferred over any other's. This is no different than talking about the judgment of some object's velocity in different frames, naturally the different frames disagree about the object's velocity, but none is preferred so there is no single objective truth about its "real" velocity.
Do you think Einstein is using a preferred frame when he says "Are two events (e.g. the two strokes of lightning A and B) which are simultaneous with reference to the railway embankment also simultaneous relatively to the train?" Do you think Taylor and Wheeler are using a preferred frame when they say "For the situation described above, the two events are simultaneous as measured in the Earth frame; they are not simultaneous as measured in the train frame." I guess everyone in the world is ignorant of the correct way to talk about simultaneity except for you, Randall?
WHICH IS EXACTLY WHAT I SAID! Seriously, what are you smoking here Randall? I have always said that events are simultaneous only relative to a particular frame (for example, that's what I was saying in the statement you just said was wrong, namely 'In the unprimed frame these events are simultaneous'), are you totally lacking in reading comprehension?
It can only be supported in the case where it is possible to send signals faster than light. If you think it's not widely agreed upon that faster than light signals + relativity = backwards in time signals, take a look at http://books.google.com/books?id=kHpaBsicVTkC&pg=PA218&dq=tachyons+causality&lr=&sig=fTBj7bP6GW5CpLzxYhxnY7_O-2E section of a popular book by theoretical astrophysicist http://www.edge.org/3rd_culture/bios/rees.html, or the bottom of p. 236 of this introductory relativity textbook, or this section on tachyons from the entry on 'backwards causality' from the Stanford Encyclopedia of Philosophy. This is quite standard stuff.
I didn't leave it out, it is in the text you quoted above. And I already defined it in post 57 which you quoted in post 59. For clarity:
Simultaneity: two events are called simultaneous if they share the same time coordinate.
Relativity of simultaneity: as a consequence of the Lorentz transform, two events which are simultaneous in one inertial reference frame may not be simultaneous in another inertial reference frame.
Grow up Randall.
