"The Amber Universe: Can an Elastic Medium Model Replace Quantum Field
0 replies · 8 views
Aleksandr Leonidovic
TL;DR
"The Amber Universe": an elastic medium where waves interfere and stable structures are particles; light speed is the medium's limit. A heuristic model, not a theory.
```bbcode
The "Amber Universe": A Wave Model of the Medium as the Foundation of Physical Reality​
Discussion topic. I would like to present to the forum a conceptual model that, in my view, offers an intuitive language for describing quantum and relativistic effects. This is not a finished theory, but rather a research program—one that I believe is worth discussing.
1. Introduction
Modern physics rests on two fundamental theories: quantum mechanics and general relativity. Both are incredibly precise in their domains, but they have not yet been unified. Conceptual difficulties remain: the probabilistic nature of measurement, wave–particle duality, the nature of mass and charge, and the problem of quantum gravity.
I propose looking at all of this from a different angle—through a wave model of the Universe as an elastic medium. In simple terms:
The Universe is a "ball of amber," an elastic substance. Energy within it is not dissipated but forms waves. Waves interfere. Stable interference groups are perceived as particles.
The purpose of this article is to formulate the model, write down its equations, show how key physical effects arise from them, and identify open questions.
2. The Basic Idea
Postulates of the model:
  1. There exists a single medium—an elastic substance filling all space.
  2. Energy in the medium is not lost but converts into waves and back.
  3. Waves interfere due to the properties of the medium and oppositely directed oscillations.
  4. Stable interference structures are what we observe as particles.
  5. Interactions are the interference of waves.
  6. Mass is energy trapped in a structure.
A simple analogy. Imagine amber. If you strike it, a wave travels through it. If you strike it in several places, the waves meet and interfere. In some places they reinforce each other, in others they cancel. Stable patterns are "particles."
3. Mathematical Model
The basic equation of the medium.
Let ψ(r, t) be the displacement of the medium. Then:
Code:
(1/c²) ∂²ψ/∂t² − ∇²ψ + V'(ψ) = 0
where c is the wave speed in the medium, and V(ψ) is the nonlinearity potential.
Relation of wave speed to medium parameters:
Code:
c = √(E/ρ)
where E is the elastic modulus and ρ is the density.
Quantization:
Code:
[ψ(r), π(r')] = iħ δ(r − r')
where π = ψ'/c² is the canonical momentum.
Lagrangian:
Code:
L = ½ [ (1/c²) ψ'² − (∇ψ)² ] − V(ψ)
4. What the Model Explains
Wave–particle duality.
A particle is a localized wave packet. It behaves as a particle (localized) but interferes and diffracts as a wave.
Interference and diffraction. The double-slit experiment is a natural property of waves in a medium. It requires no additional postulates.
Quantization. If the medium is bounded, standing waves arise. Their spectrum is discrete—hence discrete energy levels.
Creation and annihilation.
  • Creation: energy → two counter-propagating waves → interference → particle and antiparticle.
  • Annihilation: two counter-propagating waves cancel each other → particles disappear → radiation.
Mass. Mass is energy trapped in an interference node: E = mc².
Identity of particles. If all electrons are the same collective mode, they are automatically identical.
Probability. Probability is the statistics of a large number of wave events. The Born rule may emerge as a limiting theorem for large numbers.
Discreteness of masses. The discreteness of masses is a consequence of the stability of collective modes. Only those modes that correspond to eigenvalues of the medium's dynamics are stable.
5. The Speed of Light as a Limit
From the wave equation.
For a wave ψ = A·exp(i(kx − ωt)):
Code:
ω = ck
Hence:
Code:
v_phase = ω/k = c
v_group = dω/dk = c
Characteristics of the equation. The wave equation has characteristics:
Code:
x ± ct = const
A disturbance propagates within the light cone:
Code:
|x − x₀| ≤ c|t − t₀|
Causality. The medium transmits influence only through local connections. The transmission speed is c. Faster is impossible because an element does not know about a disturbance until it reaches it.
Massive particles.
Code:
v = c√(1 − m²c⁴/E²) < c
As E → ∞: v → c, but never reaches it.
Conclusion. c is not a postulate but the speed at which interactions propagate in the medium. Nothing can exceed it due to locality and causality.
6. Relation to Existing Physics
  • 19th-century ether—a medium for light.
  • Wave mechanics—particles as wave packets.
  • Solitons—stable wave structures.
  • Quantum field theory—particles as field excitations.
  • Statistical mechanics—macroscopic parameters as statistics.
  • String theory—particles as vibrational modes.
  • Hydrodynamic analogues—droplets as quantum particles.
7. Open Questions
  1. Lorentz invariance: why does the medium not create a preferred reference frame?
  2. Discreteness of masses: why do stable modes have exactly these masses?
  3. Probability: why does a measurement yield a single outcome?
  4. Spin: a vector or spinor medium is needed.
  5. Gravity: the dynamics of the medium itself is needed.
  6. Measurement: a theory of decoherence is needed.
8. What Is Needed to Turn the Model into a Theory
  1. Write down the complete system of equations of the medium.
  2. Demonstrate Lorentz invariance.
  3. Demonstrate a discrete mass spectrum.
  4. Demonstrate the emergence of probabilities and the Born rule.
  5. Demonstrate the speed of light as a limit.
  6. Include spin, charge, and gauge fields.
  7. Include gravity as the dynamics of the medium.
9. Cosmological Consequence: The Photometric Paradox
The problem.
Olbers' paradox: if the Universe is infinite, eternal, and uniformly filled with stars, the night sky should be as bright as the surface of the Sun.
The standard solution: the finite age of the Universe, expansion and redshift, and the horizon of visibility.
An alternative in the wave model. In the "amber universe" model, the dark sky may be explained by the properties of the medium: interference of waves from different sources, dispersion and spreading of packets, and attenuation of waves in the medium.
Verification.
  • Interference does not cancel energy—it redistributes it.
  • Dispersion does not remove energy—it changes the shape of the signal.
  • Attenuation requires energy to be carried away; otherwise the medium overheats.
Conclusion. The wave model can offer an alternative to the Big Bang, but not automatically. To do so, it is necessary to:
  1. Write down the equations of the medium with attenuation and dispersion.
  2. Show that they yield the observed spectra.
  3. Show that energy is not lost and does not overheat the medium.
  4. Show that all cosmological data are reproduced.
Then it will be an alternative cosmology, not merely a rejection of the Big Bang.
10. Black Holes in the Model
What a black hole is.
If the Universe is an elastic medium, then a black hole is a region where the medium loses its ability to transmit waves outward. Simply put: a "plug" in the amber where waves cannot escape.
Three possible mechanisms:
  1. Wave trapping by nonlinearity. At high energy concentration, the wave speed drops and the refractive index rises—waves cannot leave the region.
  2. Mode collapse. If the energy exceeds a threshold, the interference structure becomes stable and impenetrable to external waves.
  3. Phase transition of the medium. At a critical energy density, the medium transitions to another state—the phase boundary is the event horizon.
What is preserved:
  • The event horizon—as the boundary of an impenetrable region.
  • Gravity—as a gradient of the medium's density/elasticity (refraction).
  • Matter capture—matter loses energy to friction with the medium.
  • Hawking radiation—tunneling of waves through the boundary.
What changes:
  • There is no singularity—there is a limiting state of the medium.
  • Gravitational waves—waves in the medium, not oscillations of spacetime.
  • The information paradox—information transitions into other modes of the medium.
  • The horizon—a dynamic boundary depending on energy.
What needs to be shown: formation, stability, attraction, Hawking radiation, merger, information conservation, and agreement with LIGO/Virgo/EHT.
Summary. Black holes do not contradict the model but fit naturally into it—as regions of impenetrability of the medium, soliton structures, or phase transitions. However, their description requires refinement of the equations.
11. Conclusion
The "amber universe" model is a wave theory of everything:
  • one medium,
  • waves,
  • interference,
  • stable structures = particles,
  • energy = waves,
  • mass = trapped energy,
  • quanta = stable modes,
  • probability = ensemble statistics,
  • c = wave speed in the medium.
The model provides intuition for quantum effects, explains the unity of matter and energy, naturally introduces creation and annihilation, and derives the speed of light from the properties of the medium—but it requires answers to questions about Lorentz invariance, the discreteness of masses, probability, and measurement.
As a heuristic—powerful. As physics—a research program.
12. The Model in One Line
The Universe is elastic amber. Energy is waves. Waves interfere. Stable interferences are particles.
Question to the forum: where do you think this model breaks down first—on Lorentz invariance, on the discreteness of masses, or on probabilities?
