- #71
- 72
- 7
Yes, this is exactly what I’m trying to do, but I’m not going to make believe I understand something when I don’t.That sounds like something you should work on. You may not agree with an answer or an argument, but you should be able to get out of your own head and understand other people enough to see how they can believe something you don’t.
I think I actually do understand your argument about credence, but simply disagree with it. Others in this thread seem to have a different argument for why they believe the answer is 1/3. That is what I don’t understand.In this case the argument is exceptionally simple: I believe that the credence of a person is measured by the bet they would take as described in the blog I linked to, 1/3 is the break-even for that specific bet, and since she is rational and rational people don’t want to lose money that is the bet she would take, and hence her credence.
If you cannot understand my belief then you aren’t even trying to do so. You even agree on everything except the definition of credence. But when someone clearly explains what they mean by a word and then use that word exactly as they have explained then any lack of understanding is on the other part.
Again, you don’t have to agree with the thirder position, but at this point if you fail to understand it that is on you.
I have seen the definition that credence is a degree of belief, but that definition doesn’t lead to any number, let alone specifically to 1/2
I believe this way of leading to a number is good enough. All I’m trying to say is that she should be 0.5 = undecided . It seems like you or at least others in the thread believe she should think the probability of heads is “probably not”For example: for 2-valued, 0 = no and 1 = yes; for 3-valued, 0.5 = undecided; for 5-valued, 0.25= probably not, 0.75 = probably.![]()
No, the problem here is how to apply probability theory.It is my opinion that halfers want "credence" to have a different meaning than "probability," so that they can dismiss arguments that use probability theory.
How can you really believe that it's not 1/3
I will try once more to explain the simple logical reasoning that leads to an answer of 1/2.The point here is that "new information" includes anything she can learn about the current state, including what she knows it isn't. It does not matter what would happen in the state she knows does not correspond to the current state, just that she knows it isn't the current state. Being awake and interviewed supplies this information.
The information that sleeping beauty has before she is put to sleep is that she will soon be awakened guaranteed. She is put to sleep and sure enough soon awakened. She is told there was a coin toss but it had no effect on these events. Whether the coin landed heads or tails she was to be put to sleep and soon awakened and this is all that she knows happened.
How could she be anything other than completely unsure how the coin landed?
The second awakening does nothing. The loss of memory basically just takes her back in time to replay an event for a second time.
When thinking about it in this way the logic here just seems way too obvious to me to argue about.
