Mentor
- 37,361
- 16,496
Still looking forward to it.sisoev said:I'll come back with the experiment I mentioned earlier.
sisoev said:OK PAllen, I know where is the deceiving point in your thinking (no offence applied)
When you think SIMULTANEITY in your experiment, think that when the back(blue) light cease to exits the front(red) line die simultaneously with it
Janus said:Here's the experiment shown by animation. The white dot is the observer, the red and blue dots are the light sources. Each light source turns on and off simultaneously. The light that was emitted before this continues on its way.
Thus the observer sees in order:
1.No light
2.Red light only
3. Blue and Red light mixed(purple light)
4. Blue light only
5. No light.
[PLAIN]http://home.earthlink.net/~jparvey/sitebuildercontent/sitebuilderpictures/red-blue.gif[/QUOTE]
Thank You, Janus.
Thank You very much.
I abandoned this argument.
I was quick to use it and it wasn't in my favor :)
But thanks any way.
My last standing argument was few posts earlier, with the "purple door" experiment.
Once again Thank You :)
ghwellsjr said:No, it's not a matter of which one is moving, it's a matter of which one is changing speed or direction and where the two are in relation to each other when this happens.
So let's extend the analogy a little bit to include your question:
Suppose you are stopped and the vehicle with the siren passes you and you hear the sound drop in pitch from the high rate to the low rate and after it is a mile down the road, you take off after it at the same speed it is going. Now you will hear the pitch go from the low rate to the actual pitch of the siren, won't you? So there you both are separated by a mile, both moving and it's just like you were both stationary in terms of what you are hearing. But now if you increase your speed, you will immediately hear the pitch go higher, right? But instead of that, suppose the other vehicle slows down, will you immediately hear the pitch get higher? No, not until five seconds goes by.
Once you grasp the idea that distance causes a delay in what you observe if the other person changes speed but no delay if you are the one that changes speed, then you can easily understand the Twin Paradox with no math, no equations, no formulas.
Does this make perfect sense to you now?
DaleSpam said:Still looking forward to it.
Sorry for the late reply.DaleSpam said:The period of a pendulum is approximately [itex]2\pi\sqrt{L/g}[/itex] so the dependence is very explicit. The period of an atomic clock is proportional to [itex](m/M)\alpha^4mc^2[/itex], so I am not aware of any dependence on gravity or acceleration. A mechanical clock could probably be constructed either way, but I don't know a general formula for mechanical clocks.
g is the gravitational field, or more precisely, the proper acceleration.Buckleymanor said:I don't see how the dependence is explicit for a pendulem
I don't get your point. You could smash it with a hammer too. Once it is broken it is no longer an identically constructed clock.Buckleymanor said:Imagine a black hole with your atomic clock being sucked in and spagetification.
abbott287 said:Why do clocks that are moving closer to light speed relative to another clock tick slower? I understand that the waves take longer to reach the stationary observer on the turn around, but that's just appearance. It still seems the clocks would be in sync upon the return. What is making time actually slow down (comparatively in that frame) by moving faster??
HallsofIvy said:I'm not clear on what kind of answer you want. My reaction would be to say "that's the way the universe is". But you seem to want some kind of "mechanistic" answer.
Janus said:It isn't really due to any effect that traveling at high speed has on your clocks, it has to do with the fact that observers moving relative to each other measure time differently.
abbott287 said:Thats the hard part. I totally understand why people would measure times differently, (The ball in motion moving farther from a side "still" F.O.R.) but its due to appearance. Why someone would actually age less and why the clocks would not be in sync upon return totally fail me.
I agree. But I'm still wondering if (even the beginnings of) a mechanistic (interactional) explanation exists, or if it might be possible. Like, say, something along the line of a quantum mechanical description of relativistic differential aging. Saying that differential aging is a consequence of the speed of light being the same for all observers doesn't quite do it for me, because clocks undergo real physical changes based on their movement. Something measurable happens to oscillators when they're significantly speeded up, and the geometric explanation doesn't really account for this. Does it?DaleSpam said:I would say it is a geometric effect and that the geometry is well understood.
It does, completely. In addition, any mechanistic explanation would be hampered by the question "why don't the co-moving observers measure any difference". The geometric explanation accounts for that also.ThomasT said:Something measurable happens to oscillators when they're significantly speeded up, and the geometric explanation doesn't really account for this. Does it?
ThomasT said:I agree. But I'm still wondering if (even the beginnings of) a mechanistic (interactional) explanation exists, or if it might be possible. Like, say, something along the line of a quantum mechanical description of relativistic differential aging. Saying that differential aging is a consequence of the speed of light being the same for all observers doesn't quite do it for me, because clocks undergo real physical changes based on their movement. Something measurable happens to oscillators when they're significantly speeded up, and the geometric explanation doesn't really account for this. Does it?
I thought that it explained it as a function of changes in the distance/time ratio. But oscillators actually slow down as their speed increases. That is, they actually undergo physical changes. Don't they? How does the geometric description explain that?DaleSpam said:It does, completely.
I'm not sure what you're referring to. You mean the symmetric time-dilation effect?DaleSpam said:In addition, any mechanistic explanation would be hampered by the question "why don't the co-moving observers measure any difference". The geometric explanation accounts for that also.
I agree. I didn't mean to suggest that one contradicts or excludes the other. Just that one, the mechanistic (interactional) description is the deeper sort of explanation. The sort of thing we appeal to for real understanding of a phenomenon.harrylin said:Geometrical and physical explanations are not necessarily mutually exclusive, they are different ways of looking at the same.
That is entirely a matter of personal preference, and one I happen to disagree with completely.ThomasT said:Just that one, the mechanistic (interactional) description is the deeper sort of explanation.
Not sure what you mean by "mechanistic (interactional)", but all the interactions within a mechanical clock are also based on electromagnetic fields, in which changes propagate at the same speed for every observer.ThomasT said:But I'm still wondering if (even the beginnings of) a mechanistic (interactional) explanation exists, or if it might be possible. Like, say, something along the line of a quantum mechanical description of relativistic differential aging.
A.T. said:Not sure what you mean by "mechanistic (interactional)", but all the interactions within a mechanical clock are also based on electromagnetic fields, in which changes propagate at the same speed for every observer.
The same way that the side of a right triangle is actually physically shorter than the hypotenuse. It is just geometry, only using the Minkowski metric instead of the Euclidean metric.ThomasT said:I thought that it explained it as a function of changes in the distance/time ratio. But oscillators actually slow down as their speed increases. That is, they actually undergo physical changes. Don't they? How does the geometric description explain that?
DaleSpam said:The same way that the side of a right triangle is actually physically shorter than the hypotenuse. It is just geometry, only using the Minkowski metric instead of the Euclidean metric.
Thanks, I forgot! Regretfully Animation Shop 3 isn't freeware...ghwellsjr said:He explained how he did it in post #6:
'The frame are drawn with POV-Ray, then assembled by a GIF animator (I use Animation Shop 3).'
harrylin said:Thanks, I forgot! Regretfully Animation Shop 3 isn't freeware...
The animation of Janus (if that's the one you mean) is certainly about EM wave propagation, bouncing from mirrors; the dots make it easy to follow the reflections.Ernst Jan said:I'm trying to understand this
I understand the picture where Zoe is stationary in front of the veranda, but I do not understand the animation.
Light rays are not affected by the forward motion of the car (at least that is the second postulate, and experiments apparently confirm it).If it’s an object like a ping-pong ball going from one side of the car to the other, I would assume the ball would get the forward speed of the car. Since all objects can be pushed by the car, it would be strange to even ask why the ping-pong ball would go like the light ray in the animation. Light however doesn’t get pushed by the car, so this makes me question that it gets the forward motion of the car.
In SR there is a difference between quantity of motion and speed; as a result, speed and direction do not relate to each other like in Newton's mechanics. But I'm sure we had a thread about your question not long ago... OK I found it back with Google:In case Zoe moves, the angle in which the light ray is being sent will have to change, or the light will no longer reach the mirror. (for Zoe it will seem to go backwards in her car)
If she does change it however, there wouldn’t be any need to change her time. Instead she could just calculate the same distance as Jasper does.
My problem with the animation comes down to this:
If a light source moves from back to front it has no effect on the speed of the light, but if a light source moves sideways there suddenly is some mysterious sideways velocity of the light. [..]
If I understand you correctly, you do not use SR but another theory according to which the speed of light adds to the speed of the source. There can be no Doppler effect if the source and receiver have the same velocity (see http://en.wikipedia.org/wiki/Doppler_effect);There’s a light source of yellow light with a wavelength of 580nm in the back of a car and an observer 2m from the light source in the front of the car.
If the car is standing still it takes 1/517x1012 s for the light wave to appear. The light wave with a wavelength of 580nm will travel to the observer in 6.67x10-9 s. It will take the observer 1/517x1012 s to detect the light wave from front to end. The observer will see this as yellow light with a wavelength of 580nm.
If the car is traveling with a speed of 0.8c it will take 1/517x1012 s for the light wave to appear. In this time the light source has moved 464nm. So the distance between the front of the wave and the end is now 116nm (instead of 580nm) The light wave with a wavelength of 116nm will travel to the observer in 33.3 x10-9 s The observer will move a length L between detecting the front of the 116nm wave and the end. (L+116nm)/c = L / 0.8 so L=464nm making the observer see the light with a wave length of (464+116=) 580nm.
To prove this is right I’d need something that uses some kind of electro-magnetic wave and show it takes the waves longer at higher speeds. So I’d need a thing like an atomic clock and show it runs slower at higher speeds or I’d need a particle like a muon and show the information traveling within about its decay will take longer to reach its outer edges at high speeds. Funny thing is those are exactly the same things as are being used to proof time dilation.
My question is, what am I doing wrong or what experiment does time dilation explain that can't be explained by my view?
Nothing mysterious about it. It comes directly from Maxwell's equations for a given set of boundary conditions in different frames.Ernst Jan said:If a light source moves from back to front it has no effect on the speed of the light, but if a light source moves sideways there suddenly is some mysterious sideways velocity of the light.
Except that if it doesn't get the forward motion then you get real paradoxes. Like the light hitting a detector in one frame and not hitting the same detector in another frame.Ernst Jan said:If I assume the light ray gets the forward velocity from the moving lightsource then the calculation is correct and time for Zoe has to change. For me this seems like a good reason to say the assumption is false.
If I assume the light ray doesn't get the forward motion, then time stays the same. For me this makes sense.
harrylin said:The animation of Janus (if that's the one you mean) is certainly about EM wave propagation, bouncing from mirrors; the dots make it easy to follow the reflections.
https://www.physicsforums.com/showthread.php?t=503207
and in particular for this thread, if you'd make a similar animation as here above, you should not obtain time dilation.
You know what... I actually believe you. I'm convinced there is a perfectly good explantion why so many people think SR is TRUE and I would very much like to be one of them.It thus seems that you made a calculation error.
Sorry for the confusion. The calculation was to show that atomic clocks will run slow without the need to explain it with time dilation.Note also that you seem to suggest an imposed source frequency with a receiver; while the animation suggests a source such as a laser with a resonance frequency that is created by an optical cavity.
This makes no sense at all.DaleSpam said:Except that if it doesn't get the forward motion then you get real paradoxes. Like the light hitting a detector in one frame and not hitting the same detector in another frame.
Please elaborate; the animation seems to accurately describe Maxwell wave propagation, which is maintained in SR.Ernst Jan said:[..] Note that if the derived time dilation is TRUE, the animation is NOT correct.
??! No, that is not at all the argument there, nor here. The purpose of Physicsforums is to explain currently existing theory, that's all.[..] Thanks for the link. I read the thread and it's the same argument that you give here. SR is true and so everything that contradicts it is false. I agree with the conclusion under that premisse.
If so, I don't understand the difference with the simulation; if you simply used Maxwell, that is also what the simulation does - it's standard ray tracing.My question was why would you assume something like that, since as I showed it makes more sense not to. [quotation] No, in my calculation all speeds are absolute and c is constant.
That's the question of this thread upside-down; time dilation was first predicted by SR and subsequently measured. The question that we try to answer in this thread is why it happens.[..] Indeed, I showed there is no need to explain things with time dilation.
That is a misunderstanding: "time dilation" is just a common lable of the phenomenon; it's not an explanation of it. Other lables of the same are "clock retardation" and "running slow".[..] I need a reason why the assumptions made are TRUE or at least why those assumptions make sense. [..] Sorry for the confusion. The calculation was to show that atomic clocks will run slow without the need to explain it with time dilation.
Ernst Jan said:This makes no sense at all.
In my view there can be a "universal observer" , one that can see everything as it IS at one moment in the intuitive sense. This by pure definition means that there can be no real paradoxes like the one you describe. Note that if SR is true, such an observer is no longer possible.
