- 36,993
- 15,982
The idea of a universal observer directly contradicts the principle of relativity, and would only indirectly impact the postulate of the invariance of c if at all. However, that postulate is also tested in the list I sent.Ernst Jan said:Sorry, I thought you meant this postulate:
The speed of light in vacuum has the same constant value c in all inertial systems.
since it was the one I was questioning.
Exactly, and that reason must be added as an ad-hoc assumption if you are using a preferred observer.Ernst Jan said:This is strange, because according to me the ONLY thing different is the reason why clocks slow down. Other than that I'm using the axact same numbers.
Not all of them, no. The interferometer ones are about length or phase. The speed tests are generally about either speed or mass. There are also many that are about decay times, including ones that decay based on the weak and based on the strong interaction.Ernst Jan said:I've taken a look at the experiments in your link and I think they are all about frequencies. Is this correct?
One of the reasons that the evidence is so overwhelming is that there is such a wide variety of different mechanisms that are tested.
