Two blocks on 30° incline with different friction coefficients
3 replies · 28K views · last reply
Seiya
Two blocks with masses 4.0kg and 8.0 kg are connected by a string and slide down a 30 degree inclined plane. The coefficient of kinetic friction between the 4.0 kg block and the plane is 0.25; that between the 8.0 kg block and the plane is 0.35
a) calculate the acceleration of each block
This part is easy i got it right, don't even need anyone to check it... 4 kg = 2.775 , 8 kg =1.4750
used for both blocks : mgx-ff=ma
b) calculate the tension in the string
I said since the bottom block accelerates faster it will create a tension which means both blocks will be connected by a rigid string with a tension in it... so this means i could solve them as a system ... this is where i need someone to verify i did it right or if not correct me...
i said that
(mgx1+mgx2)-(ff1+ff2) = (m1+m2)a
They are connected so they will have a new a in common for both which comes out to 1.9 .
So now i can find the tension by using either box and the first equations trying to find their acceleration alone... instead now i have
(for the bottom box)
mgx-ff-T=m(1.9)
So i get T = 3.5N
if i use this t in a Newtons second law equation for the top one ill get 1.9 acceleration for it as well...
Can anyone let me know if i did any mistakes please? Thank you :) I really appreciate it
the equations are
m1 g sin(theeta) - mu1 m1 g cos(theeta) - T = m1 a
and
m2 g sin(theeta) - mu2 m2 g cos(theeta) + T = m2 a
check your calculations
first for a2 and then for common a.
MP
i used this for the second part... if you look at my equation but i combined them together... am i wrong?(mgx1+mgx2)-(ff1+ff2) = (m1+m2)a
if you combine them the T's cancel but i can find the T by setting it in a separate equation? what's wrong with my method?
Thanks
No the method is not wrong, I told to check the calculations because I am gatting a different answer for acceleration for the second block alone and the commom acceleration.
