Two interesting number theory tricks
  • Context: High School
  • Thread starter Thread starter Mark44
The discussion revolves around two number theory tricks involving three-digit numbers and their properties, particularly focusing on modulo 9 arithmetic. Participants share their experiences with these tricks, explore the underlying mathematical principles, and relate them to personal anecdotes.
  • One participant describes a trick where a three-digit number is manipulated through rearrangement and subtraction, leading to a result where the digits sum to 9, based on modulo 9 arithmetic.
  • Another participant reiterates the same trick and provides an example, emphasizing the consistency of the result under the described conditions.
  • Some participants propose that the trick can be extended to two-digit numbers, while others clarify that the second trick specifically requires three-digit numbers and involves reversing the digits of the first number.
  • A participant shares a personal anecdote about using the trick to impress a climber, suggesting a broader application of the trick beyond just entertainment.
  • One participant mentions a card trick unrelated to the main topic but highlights the surprise element in magic tricks, drawing a parallel to the amazement experienced with the number tricks.
  • Another participant reflects on the insights gained from the second example of the number trick, referencing a book on numerology that discusses similar concepts.
Participants generally agree on the mechanics of the first trick and its reliance on modulo 9 arithmetic. However, there is no consensus on the applicability of the tricks to different types of numbers, and some aspects of the tricks remain contested or unclear.
Some discussions touch on the limitations of the tricks, such as the requirement for unique digits in the first number and the specific conditions under which the second trick operates. There are also references to personal experiences that may not align with the mathematical principles discussed.
This discussion may be of interest to those exploring number theory, magic tricks involving mathematics, or individuals looking for entertaining ways to engage with mathematical concepts.
First trick
I learned this one a long time ago and have used it to entertain and amuse young kids. Ask your friend to write down a three-digit number without showing it to you. Then ask him or her to rearrange the digits to form a new three-digit number. After that, write whichever is the larger number above the other number, and then subtract the smaller from the larger, making sure that you don't see any of the numbers.
Then ask the young "victim" to tell you any two of the digits of the answer, with the proviso that if any of the digits is zero, that has to be one of the digits to be reported. I also ask whether the resulting answer has two digits or three.
After he or she tells you two of the digits, you tell the "trickee" the third digit. The key is that in the final answer, the three digits must sum to 9. If, for example, you are told that the digits are 4 and 8, you add the two to get 12, then add them again to get 3. The unknown digit must be 6.
Here's a different example. Suppose your victim writes down 531 and then reverses the digits to form 135. Subtracting the latter from the former results in 531 - 135 = 396. The victim reports that two of the digits are 3 and 6 (and has already stated that none of the digits is 0). A quick mental addition of the reported digits results in 9, so the remaining digit must also be 9.
The number theory behind this trick is modulo 9 arithmetic. Adding the digits of an integer (more than once if necessary) to produce a single digit results in exactly the same value as what you'd get for a remainder if you divided the integer by 9. Reversing or rearranging the digits of this integer produces exactly the same sum. When you subtract one number from another where both are in the same equivalence class, the result will be in the zero equivalence class, modulo 9. IOW, the result will be evenly divisible by 9. It is well known from number theory that numbers that are evenly divisibly by 9 have digits that sum to 9 or an integer multiple of 9.
Second trick
After doing the above, you can continue by asking your friend to reverse the digits of the final answer above, but this time add the two numbers. To make this seem like a real magic trick, ask him or her to tell you any one of the resulting digits. Report back that the remaining digits are whichever of 1, 0, 8, and 9, that you weren't told. I tried this out on my 8-year-old grandson last night, who had some help from his grandmother doing the arithmetic. I had hoped that he would find it interesting, but it turned out that he was completely amazed by it and loved it, going so far as to draw a heart.
Note that the first trick will work with two-digit numbers, three-digit numbers, and so on, and that to get the second number one can rearrange the digits in any order. Presumably the rearranged number is different from the first, or else the result will be zero. The second trick works only on three-digit numbers, and only when the second number is obtained by reversing the digits of the first number.
Here's an example.
First number ----- 842
Second number -- 248
Difference ----- 594
Rev. digits ----- 495
Sum ----- 1089
I've figured out why this works. Can you?
Mark44 said:
First trick
Second trick
Here's an example.
Sum ----- 1089
I did this trick once on a climber. I was browsing through his climbing guide book and told him I had memorised all the climbs. All I had memorised was the description of the 9th climb on page 108. So, of course, by this method I got him to pick a climb supposedly at random, then reeled off the name and description of the climb - much to his amazement, I'm pleased to say.
I liked a card trick that the YouTube channel Scam Nation streamed. The host is a magician, and a friend stopped by to show the host a new card trick.
The host was blown away by it and asked how he did it because, as a magician, he couldn't figure it out.
The trick was the trick didn't always work when the host heard that he was floored.
The friend continued by saying he would casually tell the audience, "Let's try that again."
To get back to the theme of this thread, number theory rather than card tricks, the second example I showed held a lot of number theory insights for me. By way of explanation, I found this example in a book called "Number 9" (IIRC). It was mostly a book on New Age numerology that belonged to my stepdaughter.
Anyway, to recap the first example, start with a 3-digit number whose first and last digits are unique. Reverse the digits and then subtract the smaller number from the first. The result you get will always be such that its digits sum to 9. The secret behind this fact is the if the first number is x mod 9, so will be the version with digits reversed, so the difference of the two numbers will be 0 mod 9. Hence the digits of the result will have to sum to 9 or a multiple of 9.
The interesting part, at least IMO, is what I gave as Example 2. If you start with the result of the operation described in the previous paragraph, and then reverse its digits, adding these two numbers always results in 1089. The number theory underlying this fact is that the result of subtracting a reversed-digits version of a number from the original (assuming the original is the larger of the two) always produces a number that is a multiple of 99. The only possible answers are 99, 198, 297, 396, 495, 594, 693, 792, 891, or 990.
Notice that the middle digit is always 9. Also note that the first and last digits sum to 9. Because the digits of all these numbers add to 9, they are all divisible by 9. Because the sum of the even digits is equal to that of the odd digits, each of these numbers is divisible by 11. This is a seldom-taught property of divisibility; i.e., that if the even-index digits of an integer add up to the same value as the odd-index digits, the number is divisible by 11.
Finally, and the key to the second example, if you take the n-th number (with 99 at index 1) in the list 99, 198, ..., 990, its reversed version will be at position (11 - n) and the sum will be 1089. This number is also a multiple of 11 by virtue of its even digits and odd digits adding to 9 and is also a multiple of 99.
  • · Replies 17 ·
11K
