Two objects kicked at different angles reach same height
5 replies · 3K views · last reply
shayshay00
Two objects are kicked upward at different angles. Object A travels a greater horizontal distance than object B. Both reach the same maximum height. Which of the following statements about the objects are true? You may select more than one.
1.Object A is in the air for a longer time than object B.
2.Both objects are in the air for the same amount of time.
3.The initial velocities of both objects have the same magnitude.
4.The vertical component of B's initial velocity is larger than the vertical component of A's initial velocity.
5.The vertical component of their initial velocities are the same.
6.The magnitude of object A's initial velocity is larger than the magnitude of object B's initial velocity.
7. The initial velocities of the objects have the same magnitude.
8.Object B is in the air for a longer time than object A.
I thought statements 2,3,4 and 7 were right.
I thought statements 2,3,4 and 7 were right. [/B]
Explain why do you think 2, 3, 4 , 7 are right.
The key, I think, is to consider the vertical component separate from the horizontal component, as if they are unrelated.
If you pretended to view this experiment directly along the line of the trajectory, and with only one eye open, you would witness only the vertical components.
This is particularly useful for examining option 2.
The rest follow.
y=-1/2gt^2 + v(initial)t + y0
If I use that equation and both are in the air for the same amount of time and they reach the same height, would four still be true?
Specific to that equation, what is the direction component of v(initial) ?
The vertical direction.
It's a rhetorical question.
