Two people accelerating toward each other 48m apart
5 replies · 2K views · last reply
ThatGuyNick
persons 1 & 2 are initially at rest (vi=0m/s) 48m (d) apart. they then run towards each other at constant accelerations
person 1 acceleration = 0.50m/s2
person 2 acceleration = 0.30m/s2
how long until they reach each other/collide (t)?
at the instant they collide, how far has object one gone (xf1)?
for convenience, we will place the origin at the starting point of the first object
where d=+48m is the initial position of the second object
x1=1/2a1t2
x2=d+1/2a2t2
when x1 = x2, the players collide at time t = t1 = t2
1/2a1t2 = d + 1/2a2t2
note that a1 = +0.50m/s2, while a2=-0.30m/s2 since the first person accelerates in the +x direction and the second person in the -x direction
how to solve for t?
Hello Nick, ##\qquad##:welcome:
You bring all terms involving t to one side and all known terms to the other side of the = sign.
It seems to me you are so intimidated by the expression that you don't recognize it as a simple quadratic equation. Unnecessary!
The persons do not collide when x1=x2. I would let x1=d and x2 =48-d.
But simplest would be to consider the relative acceleration in which case simply use d=48m for determination of t after which the respective distances should be straightforward.
Yes they do.
BvU said:
Yes they do.
True enough - the vector displacements from common reference point must be the same and so apologies to the OP who set up his equations correctly. I was thinking in terms of the scalar distances from separate starting points to the collision point.
x1=1/2a1t2
x2=d+1/2a2t2
how to solve for t?
If you write ##t^2 = S##, your equation becomes ##0.25 S = 48 - 0.15 S.## Can you figure out how to get ##S?##
