Two questions on colligative properties.
  • Thread starter Thread starter mikepl1
    Properties
The discussion focuses on two problems related to colligative properties in chemistry. The first problem involves calculating the mass percentage of sucrose solutions that boil at 235-240 degrees Fahrenheit, yielding a range of 89.5% to 91.2%. The second problem requires determining the mass of glucose needed to raise the boiling point of water to 102.36 degrees Celsius, resulting in a requirement of 213 grams of glucose. These calculations utilize the principles of colligative properties and boiling point elevation.
  • Understanding of colligative properties in chemistry
  • Knowledge of boiling point elevation and its calculations
  • Familiarity with molar mass calculations
  • Basic skills in temperature conversion between Celsius and Fahrenheit
  • Study the concept of colligative properties in detail
  • Learn how to calculate boiling point elevation using the formula ΔT = i * Kb * m
  • Explore molar mass calculations for various compounds
  • Practice temperature conversion techniques between Celsius and Fahrenheit
This discussion is beneficial for chemistry students, educators, and anyone interested in mastering colligative properties and their applications in real-world scenarios, such as cooking and food science.
mikepl1
Could anyone help me with these two problems? The answer for the first one is 89.5%- 91.2% and the second one is 213 grams of glucose, but I didn't get those answers.
1. In making candy, a certain recipe calls for heating an aqueous sucrose solution to the "soft-ball" stage which has a boiling point of 235-240 degrees Fahrenheit. What is the range of mass percentages of the solutions of sugar (C12H22O11) that boil at those two temperatures? (Hint: Remember that temperature changes are in Celsius)
2. How many grams of glucose (molar mass= 180.9 g/mol) must be dissolved in 255 g of water to raise the boiling point to 102.36 deg. Celsius?
Hi mikepl1, Welcome to PF!
As per the forum rules, you need to show us your attempt at the problem before asking for help. :)
15K
