superg33k said:
This is not correct. Manifestly covarient refers to an equation that holds under lorentz transform. E.g. an equality of energy-momentum tensor in one frame therefore be true it in any other frame, it is manifestly covarient equation
No, I'm afraid you are wrong. "Covariant" means that something transforms as a tensor under Lorentz transformations (or equivalently, that a given equation holds in any Lorentz frame).
"Manifest" is being used in its ordinary English sense. It means "obvious", "explicit", or "clear from the notation itself". Hence my reference to index notation, which is designed specifically to make covariance manifest.
Even further, a manifestly covarient equation does not have to be made up of tensors. Covarient differentiation is a manifestly covarient equation, although neither of its components (the reimann curvature tensor, or a derivitate) generally transforms like a tensor.
This does not contradict what I said. Yes, covariant derivatives are another example of an object that is manifestly covariant.
To the OP:
To see the difference between "covariant" and "manifestly covariant", consider the temporal gauge
[tex]A_0 = 0[/tex]
This expression obviously breaks Lorentz covariance, because one component of A is being singled out for special treatment. The temporal gauge condition is not preserved under Lorentz transformations.
This would seem to break the Lorentz covariance of the physics, but the neat fact is that it doesn't! The vector potential A is not a directly physical quantity; only the electromagnetic 2-form F is. And it turns out that even with the above gauge choice, the actual
physics remains Lorentz covariant. So here is an example of covariance which is
not manifest.
