Unicycle straight line motion/time dependent acceleration Problem
9 replies · 3K views
chiamocha
Here is the problem I have been trying to figure out for the past hour.
A unicycle is traveling in a straight line, along the x axis. At t=0, the unicycle is at x = D. Initially the cyclist is accelerating backwards, in the minus x direction. Over time, the acceleration increases. The time-dependent acceleration is ax(t) = -2a + 6dt The quantities a and d are constants.
All I know is the equations of constant acceleration vx(t) = v0x + ax(t)
position x(t) = x0 + v0xt + (1/2)axt2
vx2= v02x+2ax(x-x0)
What I did to attempt this equation (sorry I am not very good at coding this properly so I will just write it out) is to integrate the equation for time dependent acceleration that was given to get equations for velocity [v = v(initial) +(from 0 to t) ∫ (a) dt'] and then for position[ x = x(initial) + (from 0 to t) ∫(v)dt']. And then since it is given that at time t=0 the object is at position D I plugged that in and since I assume (I am not sure I am correct in this assumption) that the initial position of the object is 0, I set the integral of v from 0 to t equal to D. And I am not sure where to go from there. And I am not sure how to account for the backwards acceleration in the minus x direction, and then change when over time the acceleration increases.
Hmmm... not sure what you're getting at.
If your looking for the position function, integrate it, plug in your initial conditions for your velocity (I don't recall you giving a magnitude, just a direction? ) then integrate again and use your initial conditions for position to solve for your constant if integration again.
From what you gave, I'm not sure that integrating from 0 to t should give you zero. Definitely not on your velocity (unless you're trying to solve for when it DOES equal 0), which is not t-0 as you stated that the cyclist was moving backwards.
Also I believe you said at t-0 the position was D, also not necessarily 0. If it was zero, likely your prof would use 0 and not D. Can't really do a whole lot other than limiting your first constant of integration with the given conditions, and thus limiting your second one (or getting it in terms of the first)
But again... you really didn't ask a question.
Also, these numbers look really cooked, just pointing that out.
Sorry, the question is to find the velocity and position of the unicycle as a function of time.
Isn't it the derivative of the position?
The problem statement defines acceleration versus time:
[tex]a_x(t) = (-2a \ + \ 6)\ \Delta t[/tex]
Integrate this twice adding a constant of integration (v0 for the first integration, x0 for the second integration) for each integration step. The problem states that the unicycle is traveling in a straight line, but doesn't define the initial velocity v0. It does define the initial postion x0 as D.
