Using a Logarithmic Transformation for a Simpler Random Walk Model
16 replies · 2K views
WMDhamnekar
MHB
Let ## X_1, X_2, . . . ## be independent, identically distributed random variables with ##\mathbb{P}\{X_j=2\} =\frac13 , \mathbb{P} \{ X_j = \frac12 \} =\frac23 ##
Let ##M_0=1 ## and for ##n \geq 1, M_n= X_1X_2... X_n ##
1. Show that ##M_n## is a martingale.
2. Explain why ##M_n## satisfies the conditions of the martingale convergence theorem.
3. Let ##M_{\infty}= \lim\limits_{n\to\infty} M_n.## Explain why ##M_{\infty}=0## (Hint: there are at least two ways to show this. One is to consider ##\log M_n ## and use the law of large numbers. Another is to note that with probability one ##M_{n+1}/M_n## does not converge.)
4. Use the optional sampling theorem to determine the probability that ## M_n## ever attains a value as large as 64.
5. Does there exist a ##C < \infty ## such that ##\mathbb{E}[ M^2_n ] \leq C \forall n ##
No relevant equations
Answer to 1.
Answer to 2.
How would you answer rest of the questions 4 and 5 ?
Office_Shredder said:
Why does ##ln(M_n)=ln(M_{n-1})##?
Sorry, if ##\log{M_n} =0, \log{M_{n-1}}=\frac13 \log{2}## or ##\frac23 \log{\frac12}##
Whatever it may be, we can't say ## M_{\infty} =0 ##
This feels like you're looking backwards - why are you computing what ##\log(M_{n-1})## ?
What is ##E(\log(M_{n+1})-\log(M_n))##
##(\log\{E[M_{n+1}]=1\} -\log\{E[M_n=1]\}) = 0-0 =0##
The expected value of log of ##M_n## s not 1. Your answer for part three is wrong, the book is right. Try computing that expected value from the definition.
##E[X_n] = 2\times \frac13 + \frac12\times \frac23= 1##
##E[M_n]=X_1X_2...X_n= 1= E[M_0]##
##E(\log(M_n))\neq \log(E(M_n))##!
That means you want to say ##\lim\limits_{n\to\infty}E[\log{M_{\{n+1\}}}=0]=0 ##
##\therefore## by using the Law of large numbers ##M_{\infty}=0##
Author said another way to prove ##M_{\infty}=0## is ## \mathbb{P}[\lim\limits_{n\to\infty}\displaystyle\sum_{n=0}^{n}\frac{M_{n+1}}{M_n}=\infty]## i-e the sequence ##\frac{M_{n+1}}{M_n} ## does not converge.
Answer to 4.
After using the Optional sampling theorem I determined the ##\mathbb{P}[M_n=64]=\frac{1}{3^6}## Is this answer correct?
This notation doesn't make any sense to me to be honest. Maybe we can start with, what is ##E(\log(M_1))##?
Answer to 4.
That's the odds you hit 2 six times in a row at the start, so it has to be too small. Can you show your work?
Reply
Sorry, :sorry: Answer to 3 and 4 are wrong. Answer to 4 is ##\frac{1}{2^6}##
Now, Let me move on to answer 3.
##M_n= X_1X_2...X_n \therefore M_1= X_1.## Now ##X_1## may be 2 or ##\frac12 \therefore \log{M_1}=0, \therefore E[M_1]=1=E[M_0] ## So,my answer is still ##M_{\infty}=1## But the author said ##M_{\infty}=0##
How is that?😕🤔
How is that?😕🤔
You haven't done anything with the fact that 2 and 1/2 are not equally likely!
##E(\log(M_1))= \frac{1}{3}\log(2)+\frac{2}{3}\log(\frac{1}{2})## . This is *not* equal to 0
Reply
Answer to 3.
## \because \lim\limits_{n\to\infty} M_n= 2^n\times (\frac13)^n +(\frac12)^n \times (\frac23)^n =0 \therefore M_{\infty}=0##
Answer to 5.
Yes. There exists a ##(C < \infty ): \mathbb{E} [M^2_n]\leq C \forall n ##
I think your answer to 4 is correct, but without seeing any work I can't say if you got it the right way.
It still looks like you're just writing random strings of symbols for number 3 (like literally, are you just putting stuff into chatgpt?) The limit you've written doesn't correspond to the limit of any object that depends on n in the problem. We don't have to cover it if you just wanted to focus on the later parts though.
Reply
Answer to 5.
Is the above answer correct?
Note: This answer is provided to me by Chat.G.P.T.
I don't understand this answer from second step onwards. If this is the correct answer, would any member explain me this answer?
I don't agree with chatgpt's answer given by me in #15.
My own computed answer is as follows:
Is my answer correct?
