Using newcommand in TikZ code on MHB
  • Topic:
  • Thread starter Thread starter karush
    Function Gaussian
5 replies · 4K views
karush
MHB
\documentclass{article}
\usepackage{pgfplots}
\begin{document}
\newcommand\gauss[2]{1/(#2*sqrt(2*pi))*exp(-((x-#1)^2)/(2*#2^2))} % Gauss function, parameters mu and sigma
\begin{tikzpicture}
\begin{axis}[every axis plot post/.append style={
mark=none,domain=-2:3,samples=50,smooth}, % All plots: from -2:2, 50 samples, smooth, no marks
axis x line*=bottom, % no box around the plot, only x and y axis
axis y line*=left, % the * suppresses the arrow tips
enlargelimits=upper] % extend the axes a bit to the right and top
\addplot {\gauss{0}{0.5}};
\addplot {\gauss{1}{0.75}};
\end{axis}
\end{tikzpicture}
\end{document}
ok I don't think MHB will process a newcommand but I don't know how to put this in the after \begin{tikzpicture} line
the problem with posting pic here is eventually they get remove and OP is useless...
this tikz code renders in overleaf but I also have many newcommands in preamble
The TikZ picture must be a fragment that starts with \begin{tikzpicture} and ends with \end{tikzpicture}.
Any other commands that are needed must be inside this fragment.
That is in particular \usepackage{pgfplots} and the \newcommand.
And since latex requires that \usepackage{pgfplots} is in the document preamble, it must be prefixed with %preamble.
The result is:
Code:
\begin{tikzpicture}
%preamble \usepackage{pgfplots}
\end{axis}
\end{tikzpicture}
\begin{tikzpicture}
\end{axis}
\end{tikzpicture}
Klaas van Aarsen said:
The TikZ picture must be a fragment the starts with \begin{tikzpicture} and ends with \end{tikzpicture}.
The result is:
Code:
\begin{tikzpicture}
\end{axis}
\end{tikzpicture}
\begin{tikzpicture}
\end{axis}
\end{tikzpicture}
ok that helps a lot
pretty new with tikz but feel I should pursue it
I thot % was a blocker
\begin{tikzpicture}
mark=none,domain=-4:4,samples=50,smooth}, % All plots: from -4:4, 50 samples, smooth, no marks
axis y line=left, % the * suppresses the arrow tips
%\addplot {\gauss{0}{0.5}};
%\addplot {\gauss{1}{0.75}};
\addplot {\gauss{0}{1}};
\end{axis}
\end{tikzpicture}
So how do I put in a fill of $P(z \le 1.75)$
I tried various lines but just got error
also I don't need the y axis
There is a template in the https://tikzimages.mathhelpboards.com/tikz/tikzlive.html that shows how to fill a part under the Guassian graph.
That template also shows a couple more tricks.
More specifically, it shows that we can use \addplot [fill=cyan, domain=-4:1.75] {\gauss{0}{1}} \closedcycle.
However, you currently have a domain that applies to every plot and takes precedence.
That domain needs to be set as default instead of forcefully for every plot, which we can do by specifying it outside the style for every plot.
We can remove the y-axis with axis y line=none.
The result is:
Code:
\begin{tikzpicture}
  mark=none,samples=50,smooth}, % All plots: 50 samples, smooth, no marks
axis x line*=bottom, % no box around the plot, only x axis
axis y line=none, % the * suppresses the arrow tips
enlargelimits=upper, % extend the axes a bit to the right and top
domain=-4:4] % Default for all plots: from -4:4
\addplot [fill=cyan!30, draw=none, domain=-4:1.75] {\gauss{0}{1}} \closedcycle;
\end{axis}
\end{tikzpicture}
\begin{tikzpicture}
\end{axis}
\end{tikzpicture}
