Does the Vacuum Solution in General Relativity Hold in the Presence of Matter?
  • Context: Graduate
  • Thread starter Thread starter Thinkor
    Vacuum
The discussion centers on the vacuum solution in General Relativity (GR) and its validity in the presence of matter. The field equation is expressed as Rab - 1/2 gab R = 8πTab, where Rab = 0 represents the vacuum solution. Participants argue that this vacuum solution should hold even when matter is present, as excavating an infinitesimal vacuum chamber does not affect the local solution. However, it is established that while individual contributions may be infinitesimal, their infinite sum can yield a non-zero result, thus invalidating the simplification of the field equation to exclude the vacuum term.
  • Understanding of General Relativity field equations
  • Familiarity with the concepts of curvature and the Einstein tensor
  • Knowledge of Gauss's law in gravitational contexts
  • Basic calculus, particularly integration and limits
  • Study the implications of the Einstein field equations in the presence of matter
  • Explore the relationship between curvature and energy-momentum tensors in GR
  • Examine the mathematical foundations of Gauss's law in gravitational physics
  • Investigate the concept of infinitesimals and their role in calculus and physics
Physicists, mathematicians, and students of General Relativity seeking to deepen their understanding of vacuum solutions and their implications in the presence of matter.
Thinkor
The general field equation for GR is
where I am setting G = 1 and c = 1.
Also, the vacuum solution is
Rab = 0
But it seems to me that this "vacuum" solution must hold even when there is matter present. Pick a point within a planet. Then excavate an infinitesimal vacuum chamber about the point. That can't affect the solution there because the local contribution to the solution is infinitesimal. Therefore, whether there is a vacuum at a point or not makes no difference, the vacuum solution still holds. Rab = 0 is a constraint on curvature that is everywhere satisfied.
So why can't the field equation then be simplified to this by replacing Rab with 0?
- 1/2 gab R = 8πTab
That makes it look a lot like Gauss's law of gravity, which does not add in a zero term representing a vacuum solution.
2\varphi = 4πρ
This makes more sense to me. The solution is determined by the sources only, not by a zero valued vacuum solution.
Did Einstein glue together two equations into one for brevity? If so, why doesn't Gauss's law need another equation? And why would a vacuum solution be needed in addition to the source term in GR?
This is not correct. You could make this argument for calculating an integral, for example. I could say "The contribution to the integral from each infinitesimal dx is infinitesimal, therefore I can ignore it and set it to zero, and the integral of any function is zero." The problem with your argument is that, while the contribution to the solution for each infinitesimal volume is infinitesimal, when I add up an infinite number of them, I get a non-zero result. Imagine taking your "inifinitesimal vacuum chamber" to be finite but small, then take the limiting procedure of taking the volume of the chamber to zero. While the volume of the chamber tends to zero, the number of chambers tends to infinity and the sum of the contributions from all of the chambers is non-zero.
- 1/2 gab R = 8πTab
2 = 4πρ
In addition to phyzguy's comments, if ##R_{ab} = 0## then clearly the field equations do not resemble ##\nabla^2 \varphi = 4\pi \rho## for non-vanishing ##\rho## because ##R_{ab} = 0## trivially implies ##R = 0## which reduces your equation to ##T_{ab} = 0##, the Newtonian analogue of which is Laplace's equation ##\nabla^2 \varphi = 0##.
Yes, thanks. I failed to recognize in it the more complex context that exists here.
  • · Replies 27 ·
  • · Replies 50 ·
  • · Replies 17 ·
