Value of intuitionistic logic
The discussion revolves around intuitionistic propositional logic (IPL), particularly its axioms and semantics. Participants explore the implications of excluding Double Negation Elimination and the Law of Excluded Middle, as well as the various semantics that can model IPL, including categorical, Kripke, and open subsets semantics.
  • Some participants note that IPL excludes Double Negation Elimination and the Law of Excluded Middle, raising questions about its implications for modeling specific "kinds of worlds".
  • Others propose that IPL can be modeled using various semantics, including categorical semantics, Kripke semantics, and open subsets semantics.
  • A participant explains that Kripke semantics focuses on the question of "Where is the proposition true?" rather than "Is the proposition true?".
  • Discussion includes the assertion that in open subsets semantics, propositions correspond to open subsets of a topological space, with logical connectives defined in terms of set operations.
  • Some participants discuss the validity of the Law of Noncontradiction in open subsets semantics, while questioning the status of the Law of Excluded Middle in IPL.
  • A participant highlights that in topological models for IPL, propositions do not receive binary truth-values, complicating the interpretation of truth in these models.
  • There is mention of the historical context of first-order intuitionistic logic and its relation to the consistency of Peano arithmetic, referencing notable figures like Gödel and Gentzen.
Participants express a range of views on the semantics of IPL, with some agreeing on the existence of multiple semantics while others contest specific interpretations and implications. The discussion remains unresolved regarding the status of the Law of Excluded Middle in IPL.
Limitations include the dependence on specific interpretations of semantics and the unresolved nature of how IPL's axioms apply across different models. The discussion also reflects varying levels of understanding regarding the implications of topological interpretations.
cianfa72
TL;DR
About the value and significance of intuitionistic logic in modeling some kind of worlds.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions).
In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem.
My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ?
Thanks.
Independent of whether IPL is "supposed to model", it does model various specific "kind of world(s)". Or in other words, there are a variety of semantics for IPL:
  • categorical semantics
  • Kripke semantics
  • open subsets semantics (aka topological semantics)
Your formulation "kind of world" sounds closest to Kripke semantics:
Wikipedia said:
Kripke semantics (also known as relational semantics or frame semantics, and often confused with possible world semantics)[1] is a formal semantics for non-classical logic systems created in the late 1950s and early 1960s by Saul Kripke and André Joyal.
That semantics is useful for exploring the relation between IPL and various systems of modal logics (for example). However, even so modal logics have many important applications in mathematical logic, they are a quite technical subject.
The open subsets semantics is probably easiest to understand: Propositions are open subsets of a topological space, "A and B" is the intersection of the subsets corresponding to A and B, "A or B" is the union of the subsets corresponding to A and B, and "A implies B" is the interior (with respect to the topology) of the subset corresponding to B united with the complement of the subset corresponding to A. (Here is the first google hit for a reference.)
Before I say some words about categorical semantics, let me mention that an important common thread between all those different semantics is that one asks "Where is the proposition true?" instead of asking "Is the proposition true?".
In categorical semantics, one looks for the type of category for which a given logic is the internal language. Some simpe prototypical examples are:
Minimal logic is essentially IPL, only the ex falso quodlibet rule ⊥⊢A is missing. So IPL corresponds essentially to the type of cartesian closed category. This means that any cartesian closed category is a model of minimal logic, and I guess those with an initial object will be a model of IPL.
  • Kripke semantics
Ok, you said semantics (plural noun) since it refers to an entire class of semantic models/interpreations and not just a single one. So for instance we talk of Kripke semantics to mean the entire class of Kripke semantic models.
gentzen said:
The open subsets semantics is probably easiest to understand: Propositions are open subsets of a topological space, "A and B" is the intersection of the subsets corresponding to A and B, "A or B" is the union of the subsets corresponding to A and B, and "A implies B" is the interior (with respect to the topology) of the subset corresponding to B minus the subset corresponding to A.
Ok, therefore in the open subset semantics (plural noun) as semantic models for IPL, the law of noncontradiction should holds regardless of the specific open subset interpretation (singolar) chosen -- i.e. ¬(P ∧ ¬P) is assigned the complement of the empty set which is open by definition of topology.
What about the Law of Excluded Middle (LEM) P ∨ ¬P ? It should correspond as well to the underlying entire set as above. Why isn't this a theorem of IPL ?
No, "semantics" just means "theory of meaning". Even so you could talk of "theories of meaning", there is no way to put "semantics" into plural form. In logic, one contrasts syntax and semantics.
Well, take the real numbers ##\mathbb R## as your topological space, and ##P:=(-\infty,0)##. Then you get ##\lnot P=(0,\infty)## and ##P\lor \lnot P=(-\infty,0)\cup(0,\infty) =\mathbb R \backslash \{0\}##.
Ah ok, so basically in logic semantic as noun doesn't exist/apply at all.
Ah, so is ##\lnot P## assigned the interior of the complement of the open subset assigned to P ?
Yes!
Ah yes, indeed thinking about it ¬P is defined as
¬P := P → ⊥
and any topological model/interpretation maps ⊥ to the empy set. Then, by using the definition of → logic connective in any topological model, one gets the result.
In any topological model for IPL, propositions are assigned open subsets of an underlying topological space by induction starting assigning open subsets to propositional variables (i.e. to atomic propositions). This semantics do not assign any binary truth-value to propositions, i.e. one can't say whether an atomic or a composite proposition is True or False in a given topological model/interpretation. The claim we can make is that a given IPL's wff (proposition) is valid iff its assigned open set is the entire space (that's open by definition of topology).
In case of first-order intuitionistical logic, the above extends to closed wffs.
Well, we still say that a proposition which is True everywhere is just True (or top ⊤), and a proposition which is True only on the empty set (or bottom ⊥/initial object) is False.
You can say that the wff is valid, if you want, but you can also just say that it is True.
Yes. No need to force this open subsets semantics over to first-order logic. The first google hit for a reference described it only as a semantics for IPL, and most other references you will find restrict themselves in the same way.
The case of first-order intuitionistical logic is of historical interest, when Gödel, Gentzen, and Heyting studied the consistency of Peano arithmetic, or rather its provability. Well understood topics in that context are Double-negation translation, Heyting arithmetic, and Brouwer–Heyting–Kolmogorov interpretation.
The relevance of intuitionistic logic today comes more from higher-order logic and type theories. Basically, the split into first-order logic and ZFC as an axiomatic first-order logic theory only works well for classical logic. For intuitionistic logic, a tighter integration between logic and set theory makes more sense.
Ok, you mean that a proposition is True on the elements of the topological model assigned open subset. Then if such a set is the entire space we can just say it is True, contrasts with the case of empty set when it is False.
Better, I'd say it is valid when it is True (in the above sense) regardless of the specific topological model/interpretation.
Yes.
Yes, good point: True is used with respect to a specific model. For statements concerning all models, a different terminology is used. When coming from the syntax side, one could just say provable. I don't remember the terminology when coming from the model/semantics side, but valid sounds right to me.
Yes, valid is understood as semantically valid.
  • · Replies 19 ·
