High School Vector multiplication and division
Multiplying or dividing a vector by a scalar modifies its magnitude, allowing for scaling up or down. For instance, a velocity vector can be adjusted to change speed, as demonstrated by increasing a car's speed from 30 mph to 60 mph by multiplying the velocity vector by 2. This operation is crucial in both mathematics and physics, as it helps in various applications like adjusting forces or velocities. The Pythagorean theorem can be used to calculate the magnitude of the resulting vector after scaling. Overall, scalar multiplication and division are essential tools for manipulating vector quantities in different contexts.
jamiebean
what is the use of multiplying and dividing a vector by a scalar?
Is this a math or a physics question? If the later, what examples to you know from physics?
Multiplying or dividing a vector by a scalar is possible to modify the module of the vector increasing or decreasing it. For example if you have the vector ## \vec{v}=(1,1)## on the plane and the scalar ##\alpha=2## the result of the product (scalar-vector) is the vector ##\vec{w}=\alpha\cdot \vec{v}=2\cdot (1,1)=(2,2)##. The module of ##\vec{w}## is equal to ##2\sqrt{2}## that is bigger respect to the module of ##\vec{v}## that is ##\sqrt{2}## (in this case in order to have the module you can use the Pythagorean theorem so ##|\vec{w}|=\sqrt{2^2+2^2}=\sqrt{8}=2\sqrt{2}## and ##|\vec{v}|=\sqrt{1^2+1^2}=\sqrt{2}##).
Ssnow
I am traveling 30 mph to the west in a car on the way to my grandmother's house. The trip is taking a long time and I want to cut the remaining travel time in half.
I can therefor multiply my velocity vector by 2 to get the new vector of 60 mph to the west.
They scale the magnitude of the vector. For example, a scalar with a value of ##2## can be used to scale the magnitude up by a factor of ##2## or down by a factor of ##2##, by multiplying or dividing, respectively, by ##2##.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 72 ·
28K
