Verifying Apostol's falling object: integrating ds/dv = bv/(c-v)
2 replies · 2K views
zenterix
Refer to example 2 of section 8.6. Use the chain rule to write
$$\frac{dv}{dt}=\frac{ds}{dt}\frac{dv}{ds}=v\frac{dv}{ds}$$
and thus show that the differential equation in the example can be expressed as follows
$$\frac{ds}{dv}=\frac{bv}{c-v}$$
where ##b=m/k## and ##c=gm/k##. Integrate this equation to express ##s## in terms of ##v##. Check your result with the formulas for ##v## and ##s## derived in the example
The cited example 2 is a bit large to be shown here in all its steps.
Here are the main points and equations.
A body of mass ##m## is dropped from rest from a great height in the earth's atmosphere. Assume it falls in a straight line and that the only forces acting on it are the earth's gravitational attraction and a resisting force due to air resistance which is proportional to its velocity.
Newton's second law tells us
$$ma=mg-kv$$
where ##k## is some positive constant and ##-kv## is the force due to air resistance.
$$mv'=mg-kv$$
is a first-order equation in velocity ##v##.
We can write this in the form
$$v'+\frac{k}{m}v=g$$
which we can solve using an integrating factor to obtain (assuming v(0)=0)
$$v(t)=e^{-kt/m}\int_0^t ge^{ku/m}du=\frac{mg}{k}(1-e^{-kt/m})$$
we can differentiate to find acceleration
$$a(t)=ge^{-kt/m}$$
We can also integrate to obtain position
$$s(t)=\frac{mg}{k}t+\frac{gm^2}{k^2}e^{-kt/m}+C$$
and if ##s(0)=0## we have
$$s(t)=\frac{mg}{k}t+\frac{gm^2}{k^2}(e^{-kt/m}-1)$$
Here is my solution to this problem. Unfortunately, I can't check it because it is not contained in the solution manual.
$$\frac{dv}{dt}=\frac{dv}{ds}\frac{ds}{dt}=v\frac{dv}{ds}$$
$$\frac{ds}{dv}=\frac{v}{v'}=\frac{v}{ge^{-kt/m}}$$
$$=\frac{\frac{m}{k}v}{\frac{gm}{k}e^{-kt/m}}$$
$$=\frac{\frac{m}{k}v}{\frac{gm}{k}-\frac{gm}{k}+\frac{gm}{k}e^{-kt/m}}$$
$$=\frac{\frac{m}{k}v}{\frac{gm}{k}-\frac{gm}{k}(e^{-kt/m}-1)}$$
$$=\frac{bv}{c-v}$$
My main question is about the integration of this expression to obtain ##s## in terms of ##v##.
$$\int_0^v \frac{ds}{dv}dv=\int_{s(0)}^{s(v)} ds = s(v)-s(0)=\int_0^v\frac{bv}{c-v}dv$$
$$=bc(\ln{(c)}-\ln{(c-v)})-bv$$
$$s(v)=s(0)+bc(\ln{(c)}-\ln{(c-v)})-bv$$
I don't recall seeing this relationship very often and so I am not sure if this is correct. The problem says to check this result with the equations derived in the cited Example 2. But that example derived equations for ##v## and ##s## relative to ##t##. How would I go about using those equations to check my result of ##s## as a function of ##v##?
I think the intention is to derive the ODE as [tex] ma = mv\frac{dv}{ds} = mg - kv[/tex] so that [tex] \frac{ds}{dv} = \frac{mv}{mg - kv} = \frac{(m/k)v}{(mg/k) - v} = \frac{bv}{c - v}.[/tex] Note that the solution to the earlier exercise can be written in the form [tex]\begin{split}<br /> v(t) &= c(1 - e^{-b/t}) \\<br /> s(t) - s_0 &= ct - bv(t).\end{split}[/tex] To show that [tex] s(v) - s_0 = bc\ln|c| - bv - bc\ln|c - v| = ct - bv = s(t) - s_0[/tex] the easiest way is to solve [itex]v(t)[/itex] for [itex]t[/itex] to obtain [tex]\begin{split}<br /> e^{-t/b} &= \frac{c - v}{c} \\<br /> t &= b\ln|c| - b\ln|c - v|.\end{split}[/tex]
Attached are the full calculations leaving ##v_0## as a variable (just for added suffering with the algebra). Unfortunately, I couldn't figure out a way to post it directly here (file either too large or too low quality).
