Volterra equation of the second kind
  • Context: Graduate
  • Thread starter Thread starter reterty
The discussion centers on solving the linear Volterra equation of the second kind, specifically the equation defined as $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with the kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$, where $\lambda_n$ are the positive roots of the Bessel function $J_0(x)$. Numerical attempts using the trapezoidal method reveal that for $\beta > 0.43$, the solution decreases monotonically, while for $\beta < 0.43$, the solution exhibits oscillations. This behavior is linked to the parameter $\beta$ and the constant $C$, which is influenced by the derivatives of $y$ at zero.
  • Understanding of Volterra equations, particularly the second kind.
  • Familiarity with Bessel functions, specifically $J_0(x)$.
  • Knowledge of numerical methods, particularly the trapezoidal method.
  • Basic concepts of oscillatory behavior in mathematical functions.
  • Explore advanced numerical techniques for solving Volterra equations.
  • Investigate the properties of Bessel functions and their roots.
  • Learn about the stability analysis of numerical solutions in differential equations.
  • Study the implications of parameter sensitivity in mathematical models.
Mathematicians, physicists, and engineers working with integral equations, numerical analysis, or those interested in the behavior of solutions to Volterra equations.
reterty
There is the following linear Volterra equation of the second kind
with kernel
where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I need a help in the solution (numerical or even analytical) of this equation.
I tried to solve this equation numerically using the trapezoidal method. A surprising result emerged: for $\beta>0.43$, the solution decreases monotonically for all positive values of the argument. If $\beta<0.43$, however, the function decreases but has a finite number of oscillations (maybe a numerical glitch?)
I don't think it is a glitch. I made the obvious and checked the first equation by using the second. And if I made no mistakes, then
0=y'(x)+y(x)-4\sum_{n=1}^\infty \dfrac{1}{\lambda^2_n}e^{-\beta\lambda_n^2 x}+\beta C\sum_{n=1}^\infty xe^{-\beta\lambda_n^2 x}
with some constant ##C,## mainly depending on ##y^{(n)}(0),## which explains the dependence on the value of ##\beta.##
10K
  • · Replies 0 ·
  • · Replies 0 ·
