B What is the Significance of the Laplace Operator in Vector Calculus?
  • B
  • Thread starter Thread starter erocored
    Laplace Operator
erocored
##\frac {\partial \vec F} {\partial x} ## + ##\frac{\partial \vec F} {\partial y} ## = vector which gives me a direction of the greatest increase of the greatest increase of the function, where ##\vec F ## = gradient of the function. If I multiple the first by ##\hat i## and the second by ##\hat j## then I will get the length of the x-component of vector ##\frac {\partial \vec F} {\partial x} ## plus the length of the y-component of vector ##\frac{\partial \vec F} {\partial y} ##. What does this sum mean?
Hi,
Your thread name is 'Laplace operator' ...
If I go from your $$F = \nabla f = {\partial f\over\partial x} {\bf \hat\imath} + {\partial f\over\partial y} {\bf \hat\jmath} $$ in 2 dimensions to your vector $$\frac{\partial \vec F} {\partial x} +\frac{\partial \vec F} {\partial y} = \Biggl({\partial^2 f\over\partial x^2}+{\partial^2 f\over\partial y\partial x} \Biggr) {\bf \hat\imath} +
\Biggl( {\partial^2 f\over\partial y^2} + {\partial^2 f\over\partial x\partial y} \Biggr) {\bf \hat\jmath} $$ Then I do not understand what you mean with
erocored said:
If I multiple the first by ##\hat i## and the second by ##\hat j##​
but let's assume you mean 'take the inner product', then I get
[edit] wrong ! Instead of first inner product then adding up I made the mistake of first adding up !
$$\frac{\partial \vec F} {\partial x} \cdot\hat\imath +\frac{\partial \vec F} {\partial y} \cdot\hat\jmath = {\partial^2 f\over\partial x^2}+{\partial^2 f\over\partial y\partial x} +
{\partial^2 f\over\partial y^2} + {\partial^2 f\over\partial x\partial y} $$And that is NOT the 2 D Laplacian ...
[edit] first doing the inner product and then the addition does yield the Laplacian:
$$\Delta \vec F = \nabla^2 \vec F = \nabla \cdot (\nabla\vec F ) =
{\partial^2 f\over\partial x^2}+{\partial^2 f\over\partial y^2}$$which you probably meant, and which does have a physical meaning .
Likes docnet and erocored
Hello, I am sorry for my mistake. Here is what I meant exactly:
I have vector ##\vec v_1## at point ##\left(x, y \right)## , vector ##\vec v_2## at point ##\left(x+dx, y \right)## and vector ##\vec v_3## at point ##\left(x, y+dy \right)## (##\vec v_1## = ##\vec F\left(x, y \right)##, ##\vec v_2## = ##\vec F \left(x+dx, y \right) ##, ##\vec v_3## = ##\vec F \left(x, y+dy \right) ##).
Then difference between ##\vec v_2## and ##\vec v_1## will be ##d\vec v_{21}##, difference between ##\vec v_3## and ##\vec v_1## will be ##d\vec v_{31}## (##d\vec v_{21}## = ##\vec F \left(x+dx, y \right) ## - ##\vec F\left(x, y \right)##, ##d\vec v_{31}## = ##\vec F \left(x, y+dy \right) ## - ##\vec F\left(x, y \right)##).
Next I will get vector ##\frac {d\vec v_{21}} {dx}## which is collinear with ##d\vec v_{21}##, and so for ##\frac {d\vec v_{31}} {dy}##.
Now if I multiple ##\frac {d\vec v_{21}} {dx}## by ##\hat i## I will get a length of the x-component of that vector and the y-component of vector ##\frac {d\vec v_{31}} {dy}## if multiple by ##\hat j##.
Sum of ##\frac {d\vec v_{21}} {dx} \cdot \hat i## and ##\frac {d\vec v_{31}} {dy} \cdot \hat j## is equal to ##\frac {\partial \vec F} {\partial x} \cdot \hat i## + ##\frac {\partial \vec F} {\partial y}\cdot \hat j##. This is also equal to
##\frac \partial {\partial x} \cdot \left(\frac {\partial f} {\partial x}\cdot \hat i + \frac {\partial f} {\partial y}\cdot \hat j \right) \cdot \hat i## + ##\frac \partial {\partial y} \cdot \left(\frac {\partial f} {\partial x}\cdot \hat i + \frac {\partial f} {\partial y}\cdot \hat j \right) \cdot \hat j## =
##\frac {\partial^2 f} {\partial^2 x} \cdot \hat i \cdot \hat i## + ##\frac {\partial^2 f} {\partial x \cdot \partial y} \cdot \hat i \cdot \hat j## + ##\frac {\partial^2 f} {\partial x \cdot \partial y} \cdot \hat i \cdot \hat j## + ##\frac {\partial^2 f} {\partial^2 y} \cdot \hat j \cdot \hat j## =
##\frac {\partial^2 f} {\partial^2 x}##+##\frac {\partial^2 f} {\partial^2 y}## = sum of the lengths of those dashed lines. I can not understand what does this sum mean.
Likes BvU
Thank you! But is it correct that the Laplace operator is equal to the sum of these dashed lines, and if so, what does this sum mean?
I don't think you made one. In contrast I screwed up grossly o:) o:) and edited my reply to correct it.
I am afraid I let you make you drawing without that helping to shed light on your original question: it's imply too complicated (at least for me). In my case, what helps here to see and fix the mistake is a 'numerical' example (below). But it still doesn't clearly show what the result signifies :frown:$$
\begin{align*}
f & = x^3y^2 + x^2y^3 \\ \ &\ \\
\vec F =\vec \nabla f & =
\Bigl (3x^2y^2 + 2xy^3 \Bigr )\; {\bf \hat\imath} + \Bigl (2x^3y + 3x^2y^2 \Bigr )\;\hat\jmath \\ \ &\ \\
{\partial \vec F \over\partial x } & =
\Bigl (6xy^2 + 2y^3 \Bigr )\; {\bf \hat\imath} + \Bigl (6x^2y + 6xy^2 \Bigr )\;\hat\jmath \\ \ &\ \\
{\partial \vec F \over\partial y } & =
\Bigl (6x^2y + 6xy^2 \Bigr )\; {\bf \hat\imath} + \Bigl (2x^3 + 6x^2y \Bigr )\;\hat\jmath \\ \ &\ \\
& =\Bigl (6xy^2 + 2y^3 \Bigr ) + \Bigl (2x^3 + 6x^2y \Bigr ) \\ \ \\
& ={\partial^2 f\over\partial x^2}+{\partial^2 f\over\partial y^2} = \Delta f
\end{align*}
So after this error of mine we can finally come to the Laplacian
The Laplacian is the divergence of a gradient: $$\Delta f = \vec \nabla\cdot(\vec\nabla f) $$ and it plays an important role in physics in the Laplace equation and in the (more general) Poisson equation.
It can be shown that a conservative force field is the gradient of some potential. And the divergence indicates the presence (or absence) of sources.
I wouldn't know how to come to that insight directly from the definitions. Only in steps in vector calculus.
Google things like Conservative vector field , Laplacian vector field , Divergence theorem ,
physical interpretation of ... (any of: gradient, curl, divergence, laplacian :smile: ),
Thank you!
Likes BvU
The last smiley was a realization that my reply is rather circular ... :wink:
