What Method Solves the ODE x^3y'+4x^2y=1/x?
  • Thread starter Thread starter pat666
    Ode
23 replies · 4K views
pat666
[tex]x^3y'+4x^2y=1/x[/tex]
NA
I've tried separation of variable but I can't get the ys on 1 side and the xs on the other.
Please help the exam is soon and I don't know what method to use?
It's a first-order differential equation, so you can always use an integration factor.
How do I do that for the non homogenous ODE?
As always, find solution to homogeneous equation. Then find particular solution. Add the two solutions together.
Ok, ill try to figure it out. I can't find the y_p value for r(x) though. Do you know what it is for 1/x?
hi pat666! :wink:
hint: the LHS is almost an exact integral, isn't it?
ok, multiply it by something to make it an exact integral (that's vela's :smile: integrating factor)
Question. what is an exact integral?
oops! :rolleyes:
i meant an exact derivative :redface:
Suppose you had a general differential equation:
[tex] p(x)\frac{dy}{dx}+r(x)y=r(x)[/tex]
The first thing to do is divide through by p(x) to obtain:
[tex] \frac{dy}{dx}+\frac{q(x)}{p(x)}y=\frac{r(x)}{p(x)}[/tex]
Then the trick is to multiply through by:
[tex] e^{\int\frac{q(x)}{p(x)}dx}[/tex]
and note that:
[tex] \frac{d}{dx}e^{\int\frac{q(x)}{p(x)}dx}=e^{\int \frac{q(x)}{p(x)}dx}\frac{q(x)}{p(x)}[/tex]
and so the LHS of the equation can be written as:
[tex] \frac{d}{dx}\left( e^{\int\frac{q(x)}{p(x)}dx}y\right) =\frac{r(x)}{p(x)}e^{\int\frac{q(x)}{p(x)}dx}[/tex]
From this I think you can solve your equation.
hunt_mat gave the general formula for the integrating factor. I perfer to think like this:
We are looking for a function u(x) so that multiplying by u(x) makes the left side of the equation,
[tex]x^3u(x)y'+ 4x^2u(x)y[/tex]
an "exact derivative". That is, it is of the form
[tex]\frac{d(x^3u(x)y)}{dx}= x^3u(x)y'+ 4x^2u[/tex]
by the product rule, that is the same as
[tex]x^3u(x)y'+ 3x^2uy+ x^3u'y= x^3u(x)y'+ 4x^2u[/tex]
so we want
[tex]3x^2u+ x^3u'= 4x^2u[/tex]
Then
[tex]x^3u'= x^2u[/tex]
which is a separable equation
[tex]\frac{du}{u}= \frac{dx}{x}[/tex]
Which is easily integrable.
I still can't do this, when I try hund_mat's method I get x^4*y'+4x^3*y=1 I don't know how to solve this either?
I need help urgently/ ODE
Solve this ODE
Separation of variables won't work and I can't find an integrating factor
hi pat666! :smile:
(try using the X2 icon just above the Reply box :wink:)
hint: what is d/dx (x4y) ? :wink:
That is 4x^3*y but where did that come from and what do I do with it?
Thanks
ahhh!
nooo :redface: … use the product rule :wink:
I'm not sure what you mean? how can the answer change by using a different rule?
you didn't differentiate the "y" :wink:
This is a linear first order differential equation. Substitute y by the product f˙g.
ehild
What is f and g? Does that mean by the product of d/dx(x^3)*?
Thanks
f(x) and g(x) are two arbitrary functions.
You have a linear differential equation y'+a(x)y=b(x) (The comma ' means d/dx)
Replace y=f(x)g(x), y'=f'g+fg':
f'g+fg'+a(x)fg=b(x), and choose f in such way that f'g+a(x)fg=0. Eliminate g. Solve for f (you need a particular solution only) and plug it into the rest of the original equation:
fg'=b(x) and find the general solution for g(x).
Try. :)
ehild
Is it an exact differential equation? I looks like, if you multiple by x, you get x4y'+4x3y=1, let f(x, y)=x4y, and you can see df/dx=x4y'+4x3y=1.
what he's saying is:
[tex] \frac{d}{dx}(x^{4}y(x))=4x^{3}y(x)+x^{4}\frac{dy}{dx}[/tex]
This question was asked before, multiply through by x and notice that you can write the LHS as a total derivative.
pat666 said:
Solve this ODE
Two threads merged. Please do not multiple post the same question.
