What values satisfy x ≤ |x| and other absolute value questions?
11 replies · 4K views · last reply
CSmith1
Can someone check these ractice questions for me thanks.i need to understand what is being asked and how to go about this.
1.) For what values is it true that x is less than equal to |x| . 2.)For what values is it true that x=|x|?3.)|z|/-|z|,z is not equal to 0
4.)|t|/|t|, t is not equal to y
5.)|y-x|-|x-y|6.)|h| if h is negative: answer---> |-h|=h7.)|-h| if h is negative8.)|x-2| if x=29.)|x-2| if x > than 2?10)|x+6|+|x-2|if 0
Re: Absolute value
A few things to notice that might help you with these is that |x| is always positive. That doesn't change if x itself is negative or positive. Similarly |x-y| = |y-x|. Why? |y-x|=|-(x-y)|=|x-y|. Let's try it with some concrete numbers. |3-5|=|-2|=2 and |5-3|=|2|=2. If you do that with any two numbers it will work out. Lastly, -|x| is always negative. That is because |x| is always positive and a positive times negative 1 is always negative. That should help you out on 1-5 I think.
Also, 9 and 10 look to have something missing from them. What is 9 asking? Is 10 saying that x=0?
Re: Absolute value
9.) |x-2| if x < (less than) 210)|x+6|+|x-2|if 0<x<1
Re: Absolute value
Ok cool. Try using the info I gave you. If you're just absolutely stuck, that's ok! Pick 1-2 problems from these and we'll address them.
Re: Absolute value
Ok this is what I am getting.
1.) |h| if h is negative
= |-h| (i laced this here since they asked for h to be negative.
=h
2.)|-h| if h is negative
= h
i turned it into a positive h3.)|x-2| if x <2
i don't really get the part when they say " if c <2"
4.)|x-2| if x = 2
should i replace the x with 2
2-2=0
5.)|x-2| if x > (greater than) 2
x+2=3
Re: Absolute value
=h
I don't understand what you did here, but here's what I got. The question is when is $h \le |h|$. When h=0 this is true. What about when h > 0? Let's pick 3. Is 3 less than or equal to? Well it is equal to, so yes that's true. In fact it's true for any positive number. What about negatives? Is -4 < |-4|? That's the same thing as -4< 4, which is true. So it's true for negatives, 0 and positives - so true for all numbers.
= h
The question is when is $h=|h|$ true? When h=0, this is true. What about when h>0? Let's pick 5.
5=|5| is certainly true and it's true for all positives. What about negatives? Is -3=|-3|? No it isn't because |-3|=3. So this is true for $h \ge 0$
3.)|x-2| if x <2
Try plugging in numbers. What do you get for x= -3? What about -4, -5, -10? Can you find a general pattern?
4.)|x-2| if x = 2
2-2=0
CORRECT
x+2=3
How did you get x+2=3? You should try some numbers bigger than 2 and see what you get. What do you get when x=3? You get |3-2|=1 or x-2. What about for x=4? x=10?
See comments above.
Re: Absolute value
even though u wrote that i still don't seem to get it...(Worried) u have to choose numbers for these ? like where it says greater then and less than
Re: Absolute value
EDIT: It looks like there was a typo in the problem so see my post below about that. I think that post should be easier to understand.
If pressed for time then from your original post I would focus on 1-7 first. Once you get those I would move onto adding and subtracting things within absolute values.
Re: Absolute value
thanks for your help .I understand everything up to the part with the clumn can u explain.i will check tommorow i have to go right now.
Re: Absolute value
but in a later post you wrote
3.)|x-2| if x <2
If the first version was correct then you can ignore my previous long post. That was all going with x being less than 2.
If x>2, what does that mean? x is anything above 2, but not including 2. Another way to say it is x can't be less than 2 or 2 itself. I don't know how you are being taught these concepts or how you think of it but those are both the same idea. You understand the differences between <, >, $\le$, and $\ge$ correct? If so, then obviously ignore this part.
So if x>2, then it could be 3, 4, 5, etc. If we plug in those numbers into |x-2| what do we get? For x=3 we get |3-2|=|1|=1. For x=4 we get |4-2|=|2|=2. That's what I was trying to say by "plugging in some numbers". With inequality problems sometimes you can use the info you have and and plug in some potential values, which can help you out.
We started with |x-2| if x>2. If x>2 then x-2 is always positive. Try to see that through the above examples or trying you own values. If x-2 is always positive then we don't need the absolute value sign.
|x-2|= x-2 <-- that's your final answer
Re: Absolute value
When \(x\) is positive \(x=|x|\)
When \(x\) is negative \(x=-|x|<|x|\)
When \(x=0,\ x=|x|\),
So \(x\le |x|\) for all real \(x\)
CB
Re: Absolute value
It would help if you type out all the questions in English, as it is 3 through 10 are not questions and we are left guessing what is wanted. Also there is a typo in 4 since we have a mystery reference to "y".
CB
