When does this derivative equal 7
  • Thread starter Thread starter fghtffyrdmns
    Derivative
5 replies · 2K views
fghtffyrdmns
Solving a derivative for when it equals to 7.
[tex]p'(t) = {88t+210}/{2\sqrt{44t^{2}+210t}[/tex]
[tex]7(2\sqrt{44t^{2}+210t}) = {88t+210}[/tex]
This is where I get stuck. Do I divied both sides by 7 then again by 2? then I would square both sides to get (88/14 - 15)^{2}. Then I expand, set it to 0 and use quadratic formula?
I'm a bit confused.
At first glance I would assume this means "find the derivative where the variable t=7" but from what you've done, I guess it must instead mean "find the value(s) of t where the derivative is 7". Is this correct?
Now, without using parenthesis it's impossible to be certain what the derivative function actually is:
but judging by your last line:
I'm now assuming you mean [tex]p'(t) = \frac{88t+210}{2\sqrt{44t^{2}+210t}}[/tex]
Again, is this correct?
Finally, if all is correct thus far, yes that is exactly how you would go about solving it :smile: But remember to check your answers because once you square both sides, you might have extra solutions that don't work.
Yes! that is what i meant :).
The problem is, though, when I get to this:
I divide out the seven on both side to get
[tex]2\sqrt{44t^{2}+210t} = {88/7t+30}[/tex]
then again by 2
[tex]\sqrt{44t^{2}+210t} = {88/14t+15}[/tex]
Now, when I square both side? do I write it like this:[tex]{44t^{2}+210t = ({88/14t+15})^{2}[/tex]
which I just expand out?
You can expand it. Don't forget that you can reduce 88/14.
How come I can't just take the square of 44t/14 and 15?
because (a+b)^2 does not equal a^2+b^2
in fact it is: a^2+2ab+b^2
try with numbers. (3+4)^2 doesn't equal 3^2+4^2
