Where do experimental particle physicists work?
The discussion centers around the workplaces of experimental particle physicists, specifically those involved in lattice quantum chromodynamics (QCD) and other experimental fields. It explores the locations and environments where these physicists typically conduct their research and the nature of their work.
  • Some participants suggest that experimental particle physicists primarily work at the experiments they are involved in, with many currently working at the Large Hadron Collider (LHC).
  • It is noted that while many projects utilizing LHC data are based at institutions worldwide, travel to the experiment site may not always be necessary.
  • One participant argues that lattice QCD is not typically associated with experimental particle physicists, asserting that it is mainly the domain of theorists who can work remotely from various locations, including universities and national labs.
Participants express differing views on the association of lattice QCD with experimental particle physicists, indicating a lack of consensus on this point. While some agree on the general workplace of experimental physicists, the specific role of lattice QCD remains contested.
There are assumptions regarding the definitions of "experimental" versus "theoretical" work in particle physics that may not be fully articulated. The discussion also reflects varying perspectives on the necessity of physical presence at experimental sites.
Uri Zlatnik
Where do experimental particle physicists work like those working in lattice quantum chromodynamics for example and other experimental particle physicists?
You will usually work at the experiment you're working on. For instance, most experimental particle physicists now will go work on the LHC, so you'll probably live and work there.
Just a little addition:
Though most projects using LHC data are 'based' at institutions all around the world: it is possible you may travel to the area that the project you work on is actually being carried out, but it is not always necessary.
Since no one has pointed it out yet, I should mention that lattice QCD is not something an experimental particle physicist typically works with. As far as I'm aware, only theorists do lattice QCD calculations, and they do it wherever they can get a job (usually universities and national labs), since they can work remotely even if they use a particular supercomputer located somewhere else to do the calculations.
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 18 ·
11K
  • · Replies 19 ·
