Which increases faster e^x or x^e ?
  • Thread starter Thread starter Roni1985
    E^x
The discussion revolves around comparing the growth rates of the functions e^x and x^e. Participants are exploring the mathematical reasoning behind which function increases faster as x approaches infinity.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to compare the functions by taking the logarithm and differentiating, questioning the validity of their assumption. Other participants challenge this approach, suggesting that the comparison requires a different method, such as using limits or derivatives directly.
Participants are actively engaging with each other's reasoning, with some suggesting the use of limits and derivatives to analyze the growth rates. There is a focus on clarifying assumptions and exploring different mathematical techniques, but no consensus has been reached on the best approach.
Some participants express concerns about the validity of taking logarithms in this context, indicating a need for careful consideration of the comparison method used. The discussion includes references to specific values and the behavior of the functions as x approaches infinity.
Roni1985
which increases faster e^x or x^e ?
My attempt was taking the log of both, assuming it doesn't change anything (is this assumption correct?)
x*ln(e) ------------------------ e*ln(x)
now I took the derivative
1 ------------------------ e/x
and I said that if
0<x<e, x^e increases faster
otherwise, e^x is faster
Is my logic correct?
Thanks
No, you can't just take the log of both. You aren't dealing with an equality you are comparing two equations. For specific values, your procedure of deriving both and comparing when one is greater works fine, but you have to derive the original equations.
In general though, exponential growth (blank^x) grows faster than x^blank (whatever that is called), and you can prove that with limits.
Thanks for the reply.
How can you prove it with limits?
lim x-> inf
and then lim x-> -inf
Or simply consider derivatives:
d/dx (e^x) = e^x and d/dx(x^e)=ex^(e-1)
These tell you how fast each function is increasing at each x, hence you can work out which function is increasing faster at each x.
But you are using the fact:
"exponential growth (blank^x) grows faster than x^blank (whatever that is called)"
I want to prove it.
how do you see that
e^x grows faster then ex^(e-1) ?
You have to consider the limit of the ratio of the two equations as x-->inf. Using l'hopital's rule, you can see the difference in the rates of change.
  • · Replies 19 ·
