Why are Bessel function solutions eigenfunctions and orthogonal bases?
2 replies · 3K views · last reply
the_dialogue
I remember some of my linear algebra from my studies but can't wrap my head around this one.
Say my solution to a DE is "f(x)" (happens to be bessel's equation), and it contains a constant variable "d" in the argument of the bessel's functions (i.,e. J(d*x) and Y(d*x)). So my solution is:
f(x)= A*J(d*x) + B*Y(d*x)
I can find a general solution for f(x) by imposing 2 boundary conditions f(x1)=f(x2)=0. That would give me an equation for f_n(x).
First question: The author calls this f_n(x) the "eigenfunctions" and the "orthogonal basis". Why is this given these names? I'm not sure why these solutions form an orthogonal basis.
Second question:
The author then states that an arbitrary vector F(x) "can be expanded in this orthogonal basis" via:
F(x)= sum{from n=1 to inf} [ a_n*f_n(x) ]
where
a_n = [ (f_n(x) , F(x)) ] / [ (f_n(x) , f_n(x) ]
What in the world is this on about? Any guidance would be helpful!
The differential equation you're solving can be written in the form
[tex]L[f(x)]=\lambda w(x) f(x)[/tex]
where L is a self-adjoint linear operator and w(x) is a weighting function. From linear algebra, you should recall that solutions to [itex]A\vec{x}=\lambda\vec{x}[/itex], where A was the matrix representing a linear transformation, were called eigenvectors with eigenvalue [itex]\lambda[/itex]. Here f(x) plays the role of [itex]\vec{x}[/itex], which is why f(x) is called an eigenfunction.
A self-adjoint linear operator corresponds to a Hermitian matrix, which has real eigenvalues and orthogonal eigenvectors (neglecting the possibility of degeneracy for now), which form a basis of the vector space. Likewise, the [itex]f_n(x)[/itex]'s are orthogonal with respect to an inner product of the form
[tex]\langle f, g\rangle=\int_a^b f^*(x)g(x)w(x) dx[/tex]
and they too form a basis of a vector space of functions.
Second question:
where
If you have a vector [itex]\vec{x}[/itex] and an orthogonal basis [itex]\{\vec{v}_1, \vec{v}_2, \cdots, \vec{v}_n\}[/itex], you can express [itex]\vec{x}[/itex] as a linear combination of the basis vectors:
[tex]\vec{x} = a_1 \vec{v}_1 + \cdots + a_n \vec{v}_n[/tex]
Taking the inner product of [itex]\vec{x}[/itex] with a basis vector [itex]\vec{v}_i[/itex], you get
[tex]\langle \vec{x},\vec{v}_i \rangle = a_1 \langle \vec{v}_1, \vec{v}_i \rangle + \cdots + a_n \langle \vec{v}_n, \vec{v}_i \rangle[/tex]
Because they're orthogonal, only the i-th term on the RHS survives, so you get
[tex]a_i=\frac{\langle \vec{x},\vec{v}_i \rangle}{\langle \vec{v}_i, \vec{v}_i \rangle}[/tex]
What the author is saying is analogous to this. Now F(x) plays the role of [itex]\vec{x}[/itex] and your [itex]f_n(x)[/itex]'s are the orthogonal basis vectors, and you get
[tex]a_i=\frac{\langle F(x),f_i(x)\rangle}{\langle f_i(x), f_i(x) \rangle}[/tex]
If you've ever worked with Fourier series before, this is what you were doing with an orthogonal basis consisting of the sine and cosine functions.
