Why are heilicty and chirality equivalent for massless particles?
The discussion revolves around the relationship between helicity and chirality for massless particles, such as photons and gluons. Participants explore the implications of these concepts in different reference frames and how they apply to both massless and massive particles, touching on theoretical aspects and interpretations of particle behavior.
  • Some participants suggest that for massless particles, chirality and helicity are equivalent because these particles travel at the speed of light, making their spin appear consistent from any observer's perspective.
  • Others argue that when a photon moves towards an observer and then passes by, its chirality appears to change, raising questions about the constancy of helicity in different frames.
  • There is a query about whether chirality changes for massive particles, with some participants asserting that chirality does not coincide with helicity due to broken chirality symmetry.
  • One participant challenges another's understanding of helicity and chirality, indicating that confusion often arises between the two concepts.
  • Another participant introduces the idea of representing states as superpositions of helicity eigenstates and suggests examining transformations under Lorentz transformations to clarify the relationship.
  • Concerns are raised about the interpretation of reference frames, particularly regarding the notion of overtaking a particle and how it affects perceived helicity.
  • Technical details are provided about the definitions of chirality and helicity, including their mathematical representations and implications for massless versus massive particles.
Participants express differing views on the relationship between helicity and chirality, particularly in the context of massless versus massive particles. The discussion remains unresolved, with multiple competing interpretations and no consensus reached.
Some limitations include the dependence on definitions of chirality and helicity, as well as the implications of reference frames in relativistic contexts. The discussion does not resolve the mathematical steps or assumptions underlying these concepts.
Superposed_Cat
Salutations, question:
For massless particles—such as the photon, the gluon, and the (hypothetical) graviton—chirality is the same as helicity; a given massless particle appears to spin in the same direction along its axis of motion regardless of point of view of the observer.
~wikipedia. I'm assuming that's because (correct me if I'm wrong) those particles would travel at c and you could not overtake them so their chirality and helicity are equal.But if a photon was coming towards you then zoomed past you surely the chirality would change because you now see it going away from you?
It is now going away, but the spin also changed its radial direction: if it was oriented towards you before, it will be oriented away from you afterwards, and vice versa.
Or, in other words, the spin is always in the direction of motion or against, and this does not change.
But then why does it change for massive particles?
does it change for massive particles? The chirality does not coincide with helicity, because chirality symmetry is explicitly broken
helicity sorry. why does for massive particles?
Please don't take this the wrong way, but do you know what either helicity or chirality are? From your questions, it doesn't look like you do.
No worries I take no offence. I just no what i read on the wiki.
Usually people understand one and are confused about the other. (And answering the question hinges on finding which one they understand) But if you don't know what either of them are, it will be difficult to explain the difference.
In fact, can't your just write your state as a superposition of helicity eigenstates, and then look at how it transforms under a lorentz transformation to see that?
V-50 I was wondering why they said you can't change your reference frame because you can't overtake it. Surely if it flyies past you it is the same as overtaking it?
P.S. thanks chrisver
Chirality (aka handedness) = ±1 is the eigenvalue of γ5. It's a Lorentz invariant, but for a particle with nonzero m it's not a constant of the motion, i.e. [H, γ5] ≠ 0.
Helicity = ±1 is the eigenvalue of σ·p/|p|. For a free particle it's a constant of the motion, but clearly not a Lorentz invariant.
The easiest way to see the relation between the two is to follow Peskin-Schroeder and use the Weyl representation, in which γ5 is diagonal,
\gamma^5 = \left(\begin{array}{cc}-1&0\\0&1\end{array}\right)
The eigenfunctions of γ5 corresponding to ±1 are denoted ψR and ψL, respectively. In terms of ψL and ψR the Dirac equation is
\left(\begin{array}{cc}-m&E + \sigma \cdot p\\E - \sigma \cdot p&m\end{array}\right) \left(\begin{array}{c}\psi_L\\\psi_R\end{array}\right) = 0
and so for m = 0 we have that ψR and ψL are also eigenstates of helicity, σ·p = ±E.
No, when you overtake a particle, you're moving faster than the particle and in your reference frame the particle is seen moving the opposite direction reversing its helicity. When a particle overtakes you you still see the particle moving in the same direction with no helicity reversal.
Thanks all esp. dauto
And perhaps to make it even more obvious, there is no preferred "centre" of a reference frame, i.e. nothing explicitly stating where "you" are relative to the particle. x=0 is not special. So nothing you measure about the particle is going to change as it zooms past some arbitrary location, except it's position of course.
Going to a different frame via a Lorentz boost is a different story though (note again that you don't have to "actually" "overtake" the particle, since "you" are not anywhere in the math)
